单片机
喜羊羊系列【设备 - 驱动器 编译进内核】
2025-01-07 来源:cnblogs
*针对不同的平台。可能放进的不是以下的文件内,仅仅做參考
1、头文件
放进:linux-3.0.8archarmplat-samsungincludeplat
led.h
#ifndef _HEAD_H
#define _HEAD_H
#define MAGIC 'h'
#define LED_ON _IOW(MAGIC,1,int)
#define LED_OFF _IOW(MAGIC,0,int)
struct led_device{
  dev_t devno;
unsigned int led_major;
struct cdev *led_cdev;
struct class *led_class;
struct device *led_device;
#endif
2、设备文件
方法一:将设备资源直接加进/linux-3.0.8/arch/arm/mach-s5pv210下的mach-smdkv210.c
①
struct platform_device s5pv210_led_device_lhy = {
.name = 's5pv210_led_lhy',
.id = 1,
static struct platform_device *smdkv210_devices[] __initdata = {
②将设备信息加入总线
改动arch/arm/mach-s5pv210/mach-smdkv210.c文件
/*加入例如以下代码*/
&s5pv210_led_device_lhy,    //新加入的
 方法二:
①将设备文件dev-led.c 放进 linux-3.0.8/arch/arm/plat-samsung
led_dev.c
#include
#include
#include
#include
.id = 1,
 ②向arch/arm/mach-s5pv210/mach-smdkv210.c(跟平台架构相关文件)加入
 ③向linux-3.0.8/arch/arm/plat-samsung/Makefile加入
obj-$(CONFIG_S3C_DEV_LED)       += led_dev.o
 ④向linux-3.0.8/arch/arm/plat-samsung/Kconfig加入
config S3C_DEV_LED
        bool 'S5PV210 LED  driver support'
        help
             s5pv210 led device support
⑤加入外部声明arch/arm/plat-samsung/include/plat/devs.h
extern struct platform_device s5pv210_led_device_lhy;
3、平台驱动
①将led_drv.c 放进linux-3.0.8/drivers/my_led
led_drv.c
#include //register_chrled
#include //class_create/ledice_create
#include //kmalloc
#include //copy_to_user/copy_from_user
#include //ioremap
#include //gpio_request
#include //s3c_gpio_cfgpin
#include      //cdev_alloc
#include
//下面是移植时须要添加的
#include
#include
#include
#include
#include
#include
static struct led_device *led_drv;
static int led_open(struct inode *inode, struct file *file)
printk(KERN_INFO'%s()-%dn', __func__, __LINE__);
s3c_gpio_cfgpin(S5PV210_GPC0(3),S3C_GPIO_OUTPUT);
s3c_gpio_cfgpin(S5PV210_GPC0(4),S3C_GPIO_OUTPUT);
return 0;
static ssize_t led_read(struct file *file, char __user *buf, size_t count, loff_t *offset)
return count;
ssize_t led_write(struct file *file, const char __user *buf, size_t count, loff_t *offset)
return 0;
static long led_ioctl(struct file *file, unsigned int cmd, unsigned long val)
printk(KERN_INFO'cmd=%d arg=%ldn', cmd, val);
switch(cmd)
case LED_ON:
gpio_set_value(S5PV210_GPC0(val),1);
break;
case LED_OFF:
gpio_set_value(S5PV210_GPC0(val),0);
break;
default:
break;
return 0;
//硬件操作方法
static struct file_operations led_fops={
.owner = THIS_MODULE,
.open   = led_open,
.write  = led_write,
.read   = led_read,
.unlocked_ioctl = led_ioctl,
static int s5pv210_led_probe(struct platform_device *pdrv){
int ret;
led_drv = kmalloc(sizeof(struct led_device),GFP_KERNEL);
if(led_drv==NULL){
printk(KERN_ERR'no memory malloc for fs210_ledn');
return -ENOMEM;
/*1. 动态注冊/申请主设备*/
ret=alloc_chrdev_region(&led_drv->devno,0,1,'dev_module');
if (ret < 0) {
printk(KERN_ERR 'unable to get majorn');
return -EFAULT;
goto out_err_1;
//从设备号中分离出主设备号
led_drv->led_major = MAJOR(led_drv->devno);
/*为cdev分配空间*/
led_drv->led_cdev  = cdev_alloc();
/*注冊硬件操作方法/初始化cdev*/
cdev_init(led_drv->led_cdev,&led_fops);
/*注冊字符设备*/
cdev_add(led_drv->led_cdev,led_drv->devno,1);
/*2. 创建设备类*/
led_drv->led_class=class_create(THIS_MODULE,'led_class');
if (IS_ERR(led_drv->led_class)) {
printk(KERN_ERR 'class_create() failed for led_classn');
ret = -ENODATA;
goto out_err_2;
/*3. 创建设备文件*/
led_drv->led_device=device_create(led_drv->led_class,NULL,MKDEV(led_drv->led_major,0),NULL,'led'); //   /led/xxx
if (IS_ERR(led_drv->led_device)) {
printk(KERN_ERR 'device_create failed for led_devicen');
ret = -ENODEV;
goto out_err_3;
/*申请GPC0_3,4引脚资源*/
gpio_request(S5PV210_GPC0(3),'LED1');
gpio_request(S5PV210_GPC0(4),'LED2');
return 0;
out_err_3:
class_destroy(led_drv->led_class);
out_err_2:
unregister_chrdev(led_drv->led_major,'led_module');
out_err_1:
kfree(led_drv);
return ret;
static int s5pv210_led_remove(struct platform_device *pdrv){
device_destroy(led_drv->led_class,MKDEV(led_drv->led_major,0));
gpio_free(S5PV210_GPC0(3));
gpio_free(S5PV210_GPC0(4));
kfree(led_drv);
return 0;
struct platform_device_id led_ids[]={
[0]={
.driver_data = 0,
static struct platform_driver s5pv210_led_driver = {
.probe = s5pv210_led_probe,
.remove = s5pv210_led_remove,
.driver = { .name = 's5pv210_led_lhy',
.owner = THIS_MODULE, },
.id_table = led_ids,
static int __devinit s5pv210_led_init(void)
return platform_driver_register(&s5pv210_led_driver);
static void __devexit s5pv210_led_exit(void)
platform_driver_unregister(&s5pv210_led_driver);
module_init(s5pv210_led_init);
module_exit(s5pv210_led_exit);
MODULE_DESCRIPTION('LED driver for Marvell PM860x');
MODULE_AUTHOR('kiron');
MODULE_LICENSE('GPL');
MODULE_ALIAS('platform:s5pv210-led');
 ②在当前文件夹的Kconfig后加入,没有就新建
config S5PV210_LED_DRV
    tristate  'led_dev  for fs210 device'
    help
        led driver is for s5pv210, choose y/m/n
 ③在当前文件夹的Makefile后加入,没有就新建
obj-$(CONFIG_S5PV210_LED_DRV) = led_drv.o
④改动上级文件夹的Makefile和Kconfig
将linux-3.0.8/drivers/Kconfig  加入
source 'drivers/my_led/Kconfig'
将linux-3.0.8/drivers/Makefile 加入
obj-y        += mydriver/
最后就是自己make menuconfig里配置选项了。
4、測试程序编译測试要使用交叉工具连
arm-none-linux-gnueabi-gcc led_test.c -o led_test
附:
将可运行文件增加到开机启动,改动根文件系统filesystem
vi  filesystem/etc/init.d/rcS
./star_app/led_test
測试程序
#include
#include
#include
#include
#include
#include
#include
#include
#include
#define MAGIC 'h'
static void my_sleep(int n){
int j;
for(j=0; j<10000000*n; j++);
int main(void)
printf('-------------------------------n'
'||   start:一闪一闪亮晶晶    ||n'
'-------------------------------n');
my_sleep(1);
int fd;
unsigned int cmd=0;
unsigned long val=0;
fd=open('/dev/led', O_RDWR);
if(fd<0){
perror('open failed!n');
exit(1);
int i;
for(i=0; i<10; i++){
if(i%2==0)
cmd=LED_OFF;
else
cmd=LED_ON;
val=3;            //亮 led3
if(ioctl(fd,cmd,val)<0){
perror('ioctl failed!n');
exit(1);
val=4;            //亮 led4
exit(1);
my_sleep(1);
close(fd);
return 0;
进入单片机查看更多内容>>
相关视频
  • 【TI MSPM0 应用实战】智能小车+工业角度编码器+血氧仪+烟雾探测器!硬核参考设计详解!
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
  • 直播回放: Microchip Timberwolf™ 音频处理器在线研讨会
  • 基于灵动MM32W0系列MCU的指夹血氧仪控制及OTA升级应用方案分享
精选电路图
  • 1瓦线性调频增强器
  • 家用电器遥控器
  • 12V 转 28V DC-DC 变换器(基于 LM2585)
  • 红外开关
  • DS1669数字电位器
  • HA1377 桥式放大器 BCL 电容 17W(汽车音频)
    相关电子头条文章
