MuJoCo关节角速度记录与可视化:监控机械臂运动状态
2026-04-09 来源:EEWorld 论坛
关节空间的轨迹优化,实际上是对于角速度起到加减速规划的控制,故一般来说具有该效果的速度变化会显得丝滑一些,不会那么生硬,这里我们结合评论区的疑问,将关节速度进行记录及可视化,可以比较直观的看到关节速度,下面通过两种方式计算关节速度:
1. 手动计算关节速度,其中timestep为仿真步长
calc_qvel = (self.last_qpos - self.q_vec[:7, self.index]) / self.model.opt.timestep2. 使用data.qvel直接取得关节速度
self.joint_velocities[self.index] = self.data.qvel[:7]两种方式计算出的关节速度基本一致,如下为完整代码:
import mujoco_viewer
import mujoco,time,threading
import numpy as np
import pinocchio
import matplotlib
# matplotlib.use('TkAgg')
import matplotlib.pyplot as plt
from mpl_toolkits.mplot3d import Axes3D
import itertools
from pyroboplan.core.utils import (
get_random_collision_free_state,
extract_cartesian_poses,
from pyroboplan.ik.differential_ik import DifferentialIk, DifferentialIkOptions
from pyroboplan.ik.nullspace_components import (
joint_limit_nullspace_component,
collision_avoidance_nullspace_component,
from pyroboplan.models.panda import (
load_models,
add_self_collisions,
add_object_collisions,
from pyroboplan.planning.rrt import RRTPlanner, RRTPlannerOptions
from pyroboplan.trajectory.trajectory_optimization import (
CubicTrajectoryOptimization,
CubicTrajectoryOptimizationOptions,
class Test(mujoco_viewer.CustomViewer):
def __init__(self, path):
super().__init__(path, 3, azimuth=180, elevation=-30)
self.path = path
def runBefore(self):
# Create models and data
self.model_roboplan, self.collision_model, visual_model = load_models(use_sphere_collisions=True)
add_self_collisions(self.model_roboplan, self.collision_model)
add_object_collisions(self.model_roboplan, self.collision_model, visual_model, inflation_radius=0.1)
data = self.model_roboplan.createData()
collision_data = self.collision_model.createData()
self.target_frame = "panda_hand"
ignore_joint_indices = [
self.model_roboplan.getJointId("panda_finger_joint1") - 1,
self.model_roboplan.getJointId("panda_finger_joint2") - 1,
np.set_printoptions(precision=3)
# Set up the IK solver
options = DifferentialIkOptions(
max_iters=200,
max_retries=10,
damping=0.0001,
min_step_size=0.05,
max_step_size=0.1,
ignore_joint_indices=ignore_joint_indices,
rng_seed=None,
self.ik = DifferentialIk(
data=data,
collision_model=self.collision_model,
options=options,
visualizer=None,
self.nullspace_components = [
lambda model_roboplan, q: collision_avoidance_nullspace_component(
model_roboplan,
data,
collision_data,
q,
gain=1.0,
dist_padding=0.05,
lambda model_roboplan, q: joint_limit_nullspace_component(
model_roboplan, q, gain=1.0, padding=0.025
theta = np.pi
rotation_matrix = np.array([
[1, 0, 0],
[0, np.cos(theta), -np.sin(theta)],
[0, np.sin(theta), np.cos(theta)]
q_start = self.getIk(self.random_valid_state(), rotation_matrix, [0.4, 0.0, 0.4])
q_goal = self.getIk(self.random_valid_state(), rotation_matrix, [0.3, 0.0, 0.5])
while True:
# Search for a path
options = RRTPlannerOptions(
max_step_size=0.05,
max_connection_dist=0.5,
rrt_connect=False,
bidirectional_rrt=False,
rrt_star=True,
max_rewire_dist=0.5,
max_planning_time=5.0,
fast_return=True,
goal_biasing_probability=0.25,
collision_distance_padding=0.0001,
print("")
print(f"Planning a path...")
planner = RRTPlanner(self.model_roboplan, self.collision_model, options=options)
q_path = planner.plan(q_start, q_goal)
print(f"Path found with {len(q_path)} waypoints")
if q_path is not None and len(q_path) > 0:
print(f"Got a path with {len(q_path)} waypoints")
if len(q_path) > 50:
print("Path is too long, skipping...")
continue
else:
print("Failed to plan.")
# Perform trajectory optimization.
# self.model.opt.timestep = 0.1
dt = self.model.opt.timestep
options = CubicTrajectoryOptimizationOptions(
num_waypoints=len(q_path),
samples_per_segment=1,
min_segment_time=0.5,
max_segment_time=10.0,
min_vel=-1.5,
max_vel=1.5,
min_accel=-0.75,
max_accel=0.75,
min_jerk=-1.0,
max_jerk=1.0,
max_planning_time=1.0,
check_collisions=False,
min_collision_dist=0.001,
collision_influence_dist=0.05,
collision_avoidance_cost_weight=0.0,
collision_link_list=[
"obstacle_box_1",
"obstacle_box_2",
"obstacle_sphere_1",
"obstacle_sphere_2",
"ground_plane",
"panda_hand",
print("Optimizing the path...")
optimizer = CubicTrajectoryOptimization(self.model_roboplan, self.collision_model, options)
traj = optimizer.plan([q_path[0], q_path[-1]], init_path=q_path)
if traj is None:
print("Retrying with all the RRT waypoints...")
traj = optimizer.plan(q_path, init_path=q_path)
if traj is not None:
print("Trajectory optimization successful")
traj_gen = traj.generate(dt)
self.q_vec = traj_gen[1]
print(f"path has {self.q_vec.shape[1]} points")
self.tforms = extract_cartesian_poses(self.model_roboplan, "panda_hand", self.q_vec.T)
self.plot(self.tforms)
self.joint_velocities = np.zeros((self.q_vec.shape[1], 7))
break
self.index = 0
self.last_qpos = self.data.qpos[:7]
def plot(self, tfs):
positions = []
for tform in tfs:
position = tform.translation
positions.append(position)
positions = np.array(positions)
fig = plt.figure()
ax = fig.add_subplot(111, projection='3d')
ax.plot(positions[:, 0], positions[:, 1], positions[:, 2], marker='o')
ax.set_xlabel('X')
ax.set_ylabel('Y')
ax.set_zlabel('Z')
plt.show(block=False)
plt.pause(0.001)
def getIk(self, init_state, rotation_matrix, pose):
while True:
self.init_state = init_state
target_tform = pinocchio.SE3(rotation_matrix, np.array(pose))
q_sol = self.ik.solve(
self.target_frame,
target_tform,
init_state=self.init_state,
nullspace_components=self.nullspace_components,
verbose=True,
if q_sol is not None:
print("IK solution found")
return q_sol
def random_valid_state(self):
return get_random_collision_free_state(
self.model_roboplan, self.collision_model, distance_padding=0.001
def runFunc(self):
self.data.qpos[:7] = self.q_vec[:7, self.index]
print(f"qpos:{self.data.qpos[:7]}")
print(f"qvel:{self.data.qvel[:7]}")
print(f"calc_qvel:{calc_qvel}")
print(self.model.nv, self.model.nq)
self.index += 1
if self.index >= self.q_vec.shape[1]:
self.index = 0
time_steps = np.arange(self.q_vec.shape[1])
fig, axes = plt.subplots(7, 1, figsize=(10, 10))
for j in range(7):
axes[j].plot(time_steps, self.joint_velocities[:, j], label=f'Joint {j + 1}', color=f'C{j}')
axes[j].set_ylabel('Angular Velocity (rad/s)')
axes[j].set_title(f'Joint {j + 1} Angular Velocity')
axes[j].grid(True)
axes[j].legend()
plt.tight_layout()
plt.show()
if __name__ == "__main__":
test = Test("./franka_emika_panda/scene.xml")
test.run_loop()以上代码展示了如何使用MuJoCo进行关节角速度的记录与可视化,以监控机械臂的运动状态。通过手动计算和直接获取两种方式,可以验证关节速度数据的一致性,并利用Matplotlib进行可视化分析。
如需查看详细视频讲解、完整代码仓库及更多相关图片,请访问原帖子:MuJoCo 关节角速度记录与可视化,监控机械臂运动状态。
原帖子内容来源:https://bbs.eeworld.com.cn/thread-1313496-1-1.html
相关文章
- MuJoCo与OMPL实现Panda机械臂RRT路径规划教程
- 机械臂轨迹规划:MuJoCo仿真与TOPPRA最优时间规划教程
- Mujoco XML配置教程:为so-arm100机械臂更换panda夹爪
- MuJoCo机械臂碰撞检测教程:接触检测方法详解
- MuJoCo键盘控制球体移动教程:实时记录位姿附代码
- 基于Pinocchio和MuJoCo的机械臂逆运动学闭环控制仿真实现
- Mujoco机械臂场景修改实操:为SO-Arm100添加桌子
- Mujoco中添加Apriltag标签并实现相机识别教程
- 夯实物理AI底座,英伟达CoRL大会连发重磅模型与仿真库
- Cincoze发表全新薄型工业显示解决方案,专为HMI与可视化升级打造
