【51单片机快速入门指南】3.1:配置外部中断触发方式和中断优先级
2022-07-19 来源:csdn
普中51-单核-A2
STC89C52
Keil uVision V5.29.0.0
PK51 Prof.Developers Kit Version:9.60.0.0
源码
stdint.h见【51单片机快速入门指南】1:基础知识和工程创建
中断知识见【51单片机快速入门指南】3:中断系统
将外部中断0和外部中断1均配置为下降沿触发,但外部中断1的优先级最高,外部中断0的优先级最低。
EXTI.c
#include #include 'intrins.h' #include 'stdint.h' #include 'EXTI.h' //定义LED管脚 sbit D1 = P2^0; sbit D2 = P2^1; //定义独立按键控制脚 sbit K3 = P3^2; sbit K4 = P3^3; void Delay20ms() //@11.0592MHz { unsigned char i, j; i = 36; j = 217; do { while (--j); } while (--i); } //P3.2 void EXTI0_Callback() interrupt 0 //外部中断0中断函数 { Delay20ms(); if(K3 == 0) { D1 = !D1; while(K3 == 0); } } //P3.3 void EXTI1_Callback() interrupt 2 //外部中断1中断函数 { Delay20ms(); if(K4 == 0) { D2 = !D2; while(K4 == 0); } } #if USE_EXTI2_EXTI3 //P4.3 void EXTI2_Callback() interrupt 6 //外部中断2中断函数 { } //P4.2 void EXTI3_Callback() interrupt 7 //外部中断3中断函数 { } #endif #if EXTI_USE_STC sfr IPH = 0xb7; #endif void EXTI0_Init(uint8_t EXTI_Type, uint8_t Priority) { #if EXTI_USE_STC IPH &= ~1; IPH |= (2 & Priority) >> 1; #endif PX0 = (1 & Priority); //设置中断优先级 IT0 = EXTI_Type; //触发方式 EX0 = 1; //打开INT0的中断允许 EA = 1; //打开总中断 } void EXTI0_Switch(uint8_t Status) { EX0 = Status; } void EXTI1_Init(uint8_t EXTI_Type, uint8_t Priority) { #if EXTI_USE_STC IPH &= ~4; IPH |= (2 & Priority) << 1; #endif PX1 = (1 & Priority); //设置中断优先级 IT1 = EXTI_Type; //触发方式 EX1 = 1; //打开INT1的中断允许 EA = 1; //打开总中断 } void EXTI1_Switch(uint8_t Status) { EX1 = Status; } #if USE_EXTI2_EXTI3 sfr XICON = 0xc0; sbit PX2 = XICON^3; sbit EX2 = XICON^2; sbit IE2 = XICON^1; sbit IT2 = XICON^0; sbit PX3 = XICON^7; sbit EX3 = XICON^6; sbit IE3 = XICON^5; sbit IT3 = XICON^4; void EXTI2_Init(uint8_t EXTI_Type, uint8_t Priority) { #if EXTI_USE_STC IPH &= ~0x40; IPH |= (2 & Priority) << 5; #endif PX2 = (1 & Priority); //设置中断优先级 IT2 = EXTI_Type; //触发方式 EX2 = 1; //打开INT1的中断允许 EA = 1; //打开总中断 } void EXTI2_Switch(uint8_t Status) { EX2 = Status; } void EXTI3_Init(uint8_t EXTI_Type, uint8_t Priority) { #if EXTI_USE_STC IPH &= ~0x80; IPH |= (2 & Priority) << 6; #endif PX3 = (1 & Priority); //设置中断优先级 IT3 = EXTI_Type; //触发方式 EX3 = 1; //打开INT1的中断允许 EA = 1; //打开总中断 } void EXTI3_Switch(uint8_t Status) { EX3 = Status; } #endif EXTI.h #ifndef EXTI_H_ #define EXTI_H_ #include 'stdint.h' //使用外部中断2(P4.3)和外部中断3(P4.2) 貌似只有LQFP44封装的芯片才有,普通的DIP40芯片没有 #define USE_EXTI2_EXTI3 1 //使用STC单片机的4级优先级 #define EXTI_USE_STC 1 #define EXTI_LOW_LEVEL 0 #define EXTI_FALLING 1 #if EXTI_USE_STC //STC单片机的4级优先级 #define STC_EXTI_Priority_Lowest 0 #define STC_EXTI_Priority_Lower 1 #define STC_EXTI_Priority_Higher 2 #define STC_EXTI_Priority_Highest 3 #endif //传统51单片机的2级优先级 #define EXTI_Priority_Low 0 #define EXTI_Priority_High 1 void EXTI0_Init(uint8_t EXTI_Type, uint8_t Priority); void EXTI0_Switch(uint8_t Status); void EXTI1_Init(uint8_t EXTI_Type, uint8_t Priority); void EXTI1_Switch(uint8_t Status); #if USE_EXTI2_EXTI3 void EXTI2_Init(uint8_t EXTI_Type, uint8_t Priority); void EXTI2_Switch(uint8_t Status); void EXTI3_Init(uint8_t EXTI_Type, uint8_t Priority); void EXTI3_Switch(uint8_t Status); #endif #endif main.c #include #include 'intrins.h' #include 'stdint.h' #include 'EXTI.h' void main(void) { EXTI0_Init(EXTI_FALLING, STC_EXTI_Priority_Lowest); EXTI1_Init(EXTI_FALLING, STC_EXTI_Priority_Highest); while(1) { } } 实验现象 按下K3,D0翻转;按下K4,D1翻转。 当按住K3时(处理外部中断0时),仍可响应外部中断1; 当按住K4时(处理外部中断1时),不能响应外部中断0。
- 六大全新产品系列推出,MCX A微控制器家族迎来创新
- 意法半导体全新STM32C5系列,重新定义入门级微控制器性能与价值,赋能万千智能设备
- 从控制到系统:TI利用边缘AI重塑嵌入式MCU的边界
- 模组复用与整机重测在SRRC、CCC、CTA/NAL认证中的实践操作指南
- 有源晶振与无源晶振的六大区别详解
- 英飞凌持续巩固全球微控制器市场领导地位
- 使用 Keil Studio for Visual Studio Code开发 STM32 设备
- 蓝牙信道探测技术原理与开发套件实践
- LoRa、LoRaWAN、NB-IoT与4G DTU技术对比及工业无线方案选型分析
- Microchip 推出生产就绪型全栈边缘 AI 解决方案,赋能MCU和MPU实现 智能实时决策
