单片机
基于linux操作系统下s5pv210板子的按键中断实验
2024-12-17 来源:cnblogs
首先,在做这个实验之前有三件事是要明确的:
1. linux下的中断实验不需要像裸机实验一样要自己写取消屏蔽,清除中断标志位的操作,系统会自动帮你完成;
2.中断号的申请我使用的是gpio_to_irq()这个宏,它会帮我们自动分配中断号,返回值为中断号;
3. 在每个板子配套来的内核代码大部分都是已经包含了按键中断驱动,如果想另自己写的按键中断驱动不与内核本身带的发生中断号上的冲突,应先找到内核代码下的arch/arm/mach-s5pv210/mach-mini210.c中的gpio_bottons中的对按键初始化的代码注释掉(其他板子也类似),如下代码所示:
static struct gpio_keys_button gpio_buttons[] = {
        .gpio        = S5PV210_GPH2(0),
        .code        = 158,
        .desc        = 'BACK',
        .active_low    = 1,
        .wakeup        = 0,
        .gpio        = S5PV210_GPH2(1),
        .code        = 102,
        .desc        = 'HOME',
        .active_low    = 1,
        .wakeup        = 1,
        .gpio        = S5PV210_GPH2(2),
        .code        = 139,
        .desc        = 'MENU',
        .active_low    = 1,
        .wakeup        = 0,
        .gpio        = S5PV210_GPH2(3),
        .code        = 232,
        .desc        = 'DPAD_CENTER',
        .active_low    = 1,
        .wakeup        = 0,
        .gpio        = S5PV210_GPH3(0),
        .code        = 105,
        .desc        = 'DPAD_LEFT',
        .active_low    = 1,
        .wakeup        = 0,
        .gpio        = S5PV210_GPH3(1),
        .code        = 108,
        .desc        = 'DPAD_DOWN',
        .active_low    = 1,
        .wakeup        = 0,
        .gpio        = S5PV210_GPH3(2),
        .code        = 103,
        .desc        = 'DPAD_UP',
        .active_low    = 1,
        .wakeup        = 0,
        .gpio        = S5PV210_GPH3(3),
        .code        = 106,
        .desc        = 'DPAD_RIGHT',
        .active_low    = 1,
        .wakeup        = 0,
        .gpio        = S5PV210_GPH1(7),
        .code        = 102,
        .desc        = 'HOME',
        .active_low    = 1,
        .wakeup        = 1,
下面给出完整代码:
 1 #include
 2 #include
 3 #include
 4 #include
 5 #include
 6 #include
 7 #include
 8 #include
 9 #include
11 #define GPH2CON 0xe0200c40
13 irqreturn_t key_irq(int irq, void * dev_id)
14 {
15     //1. 检测是否发生了按键中断
18     //2. 清除已经发生的按键中断
19
21     //3. 打印按键值
22     printk('key down!n');
23
24     return 0;
25 }
26
27 int key_open (struct inode *inode, struct file *filp)
28 {
29     return 0;
30 }
31
32 void key_hw_init()
33 {
34     //unsigned int data;
35     unsigned int *gpio_config;
36
37     gpio_config = ioremap(GPH2CON,4);
38     //data = readl(gpio_config);
39     //data &= ~0b1111;
40     //data |= 0b1111;
41     writel(0x0000000f,gpio_config);
42 }
43
44 struct file_operations key_fops =
45 {
46         .open = key_open,
47 };
48 struct miscdevice key_miscdevice =
49 {
50     /*MISC_DYNAMIC_MINOR代表动态分配次设备号,即由系统自动分配*/
51     .minor = MISC_DYNAMIC_MINOR,
52     .name = 'key_miscdev',
53     .fops = &key_fops,
54 };
55
56 static int key_init()
57 {
58     /*注册混杂设备*/
59     misc_register(&key_miscdevice);
61     /*申请中断,如果内核中已有按键中断驱动,则需要把arch/arm/mach-s5pv210/mach-mini210.c文件的gpio_buttons定义的相关按键去掉,
62      不然板子上的按键中断就已经被占用,不能注册中断*/
63     /*注意:中断号这个参数应该用gpio_to_irq(S5PV210_GPH2(0)),假如用了IRQ_EINT16_31则按键驱动不会工作*/
64     request_irq(gpio_to_irq(S5PV210_GPH2(0)), key_irq, IRQF_TRIGGER_FALLING, 'key_miscdev', 0);
65     request_irq(gpio_to_irq(S5PV210_GPH2(1)), key_irq, IRQF_TRIGGER_FALLING, 'key_miscdev', 0);
66     request_irq(gpio_to_irq(S5PV210_GPH2(2)), key_irq, IRQF_TRIGGER_FALLING, 'key_miscdev', 0);
67     request_irq(gpio_to_irq(S5PV210_GPH2(3)), key_irq, IRQF_TRIGGER_FALLING, 'key_miscdev', 0);
68
69     return 0;
71 }
72
73 static void key_exit()
74 {
75     /*注销设备*/
76     misc_deregister(&key_miscdevice);
77 }
78
79 MODULE_LICENSE('GPL');
81 module_init(key_init);
82 module_exit(key_exit);
进入单片机查看更多内容>>
相关视频
  • 【TI MSPM0 应用实战】智能小车+工业角度编码器+血氧仪+烟雾探测器!硬核参考设计详解!
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
  • 直播回放: Microchip Timberwolf™ 音频处理器在线研讨会
  • 基于灵动MM32W0系列MCU的指夹血氧仪控制及OTA升级应用方案分享
精选电路图
  • 1瓦线性调频增强器
  • 家用电器遥控器
  • 12V 转 28V DC-DC 变换器(基于 LM2585)
  • 红外开关
  • DS1669数字电位器
  • HA1377 桥式放大器 BCL 电容 17W(汽车音频)
    相关电子头条文章
