来认识一下S5PV210 的VBPDE和VFPDE
2024-12-19 来源:elecfans
在代码中有
// VIDTCON0
#define VBPDE(n) (((n-1)&0xff)<<24)
#define VBPD(n) (((n-1)&0xff)<<16)
#define VFPD(n) (((n-1)&0xff)<<8)
#define VSPW(n) (((n-1)&0xff)<<0)
// VIDTCON1
#define VFPDE(n) (((n-1)&0xff)<<24)
#define HBPD(n) (((n-1)&0xff)<<16)
#define HFPD(n) (((n-1)&0xff)<<8)
#define HSPW(n) (((n-1)&0xff)<<0)
// VIDTCON2
#define LINEVAL(n) (((n-1)&0x7ff)<<11)
#define HOZVAL(n) (((n-1)&0x7ff)<<0)
#ifdef CONFIG_FB_S3C_LTE480WV
.width = 480,
.height = 272,
.bpp = 16,
.freq = 60,
.timing = {
.h_fp = 2, //HFPD_Value = 2
.h_bp = 2, //HBPD_Value = 2
.h_sw = 41,//HSPW_Value = 41;
.v_fp = 2, //VFPD_Value = 2
.v_fpe = 1,
.v_bp = 2, //VBPD_Value = 2
.v_bpe = 1,
.v_sw = 10,
.polarity = {
.rise_vclk = 0,
.inv_hsync = 1,
.inv_vsync = 1,
.inv_vden = 0,
#endif
里面的
v_fpe和h_bpe 是啥玩意呢?
在代码中有
int s3cfb_set_timing(struct s3cfb_global *ctrl)
struct s3cfb_lcd_timing *time;
u32 cfg;
time = &ctrl->lcd->timing;
cfg = 0;
cfg |= S3C_VIDTCON0_VBPDE(time->v_bpe - 1);
cfg |= S3C_VIDTCON0_VBPD(time->v_bp - 1);
cfg |= S3C_VIDTCON0_VFPD(time->v_fp - 1);
cfg |= S3C_VIDTCON0_VSPW(time->v_sw - 1);
writel(cfg, ctrl->regs + S3C_VIDTCON0);
cfg = 0;
cfg |= S3C_VIDTCON1_VFPDE(time->v_fpe - 1);
cfg |= S3C_VIDTCON1_HBPD(time->h_bp - 1);
cfg |= S3C_VIDTCON1_HFPD(time->h_fp - 1);
cfg |= S3C_VIDTCON1_HSPW(time->h_sw - 1);
writel(cfg, ctrl->regs + S3C_VIDTCON1);
return 0;
在手册有如下说明:
VBPDE [31:24] Vertical back porch specifies the number of inactive lines at the
start of a frame after vertical synchronization period. (Only for even
field of YVU interface)
VFPDE [31:24] Vertical front porch specifies the number of inactive lines at the end
of a frame before vertical synchronization period. (Only for the even
field of YVU interface).
Only for the even field of YVU interface 这个是啥意思?我在wince的VGA 1440*900 1280*720 1280*1024 当中根本没有设置这个
v_fpe和h_bpe,也就是默认就是0.在android下就有这玩意。
下一篇:9.S5PV210的时钟系统
- 六大全新产品系列推出,MCX A微控制器家族迎来创新
- 意法半导体全新STM32C5系列,重新定义入门级微控制器性能与价值,赋能万千智能设备
- 模组复用与整机重测在SRRC、CCC、CTA/NAL认证中的实践操作指南
- 有源晶振与无源晶振的六大区别详解
- 英飞凌持续巩固全球微控制器市场领导地位
- 使用 Keil Studio for Visual Studio Code开发 STM32 设备
- 从控制到系统:TI利用边缘AI重塑嵌入式MCU的边界
- 蓝牙信道探测技术原理与开发套件实践
- Microchip 推出生产就绪型全栈边缘 AI 解决方案,赋能MCU和MPU实现 智能实时决策
- LoRa、LoRaWAN、NB-IoT与4G DTU技术对比及工业无线方案选型分析
