嵌入式
stm8系列--usart收发+遇到问题
2025-09-08 来源:cnblogs
#define _maxbuf 100
typedef struct
 u8 rcbuf[_maxbuf]; //MODBUS接收缓冲区
 u16 timout;//MODbus的数据断续时间
 u8 recount;//MODbus端口已经收到的数据个数
 u8  reflag;//收到一帧数据的标志
 u8 Sendbuf[_maxbuf]; //MODbus发送缓冲区
}MYUSART;
void main(void)
    Init_UART1();
    Init_Timer4();
    enableInterrupts();
    while (1)
        if(myusart.reflag>0)
            Com_Handle();//收到什么回复什么;
            myusart.recount=0;
            myusart.reflag=0;
void Init_Timer4(void)
    TIM4_TimeBaseInit(TIM4_PRESCALER_128, 0x0f);  //1MS
  TIM4_ClearFlag(TIM4_FLAG_UPDATE);
    TIM4_ITConfig(TIM4_IT_UPDATE, ENABLE);
    TIM4_Cmd(ENABLE);
MYUSART myusart;
void Init_UART1(void)
    UART1_DeInit();
    UART1_Init((u32)9600, UART1_WORDLENGTH_8D, UART1_STOPBITS_1, UART1_PARITY_NO, UART1_SYNCMODE_CLOCK_DISABLE, UART1_MODE_TXRX_ENABLE);
    UART1_ITConfig(UART1_IT_RXNE_OR, ENABLE);
void UART1_SendData8_Buff(uint8_t* data,uint8_t len)
    uint8_t i = 0;
    for(i=0;i    {
        while(( UART1_GetFlagStatus(UART1_FLAG_TXE)==RESET));
      UART1_SendData8(data[i]);
void Com_Handle(void)//发送什么回复什么
    UART1_SendData8_Buff(myusart.rcbuf,myusart.recount);
 INTERRUPT_HANDLER(UART1_RX_IRQHandler, 18)
    /* In order to detect unexpected events during development,
       it is recommended to set a breakpoint on the following instruction.
#if 1
        if( myusart.reflag==0)
            myusart.timout=10;
            if(myusart.recount<_maxbuf)
                myusart.rcbuf[myusart.recount++]=UART1_ReceiveData8();
#endif
        UART1_ClearITPendingBit(UART1_IT_RXNE);
int time_i=0;
 INTERRUPT_HANDLER(TIM4_UPD_OVF_IRQHandler, 23)
    #if 1
    if(myusart.timout>0)
        if(--myusart.timout==0)
            myusart.reflag=1; //收到一帧数据
    #endif
    time_i++;
    if(time_i>=300)
        time_i=0;
        flag_send=1;
    //300MS
    TIM4_ClearITPendingBit(TIM4_IT_UPDATE);
 https://blog.csdn.net/taoynkkx/article/details/46821953?spm=1001.2101.3001.6650.5&utm_medium=distribute.pc_relevant.none-task-blog-2%7Edefault%7EBlogOpenSearchComplete%7ERate-5-46821953-blog-71158962.235%5Ev43%5Epc_blog_bottom_relevance_base8&depth_1-utm_source=distribute.pc_relevant.none-task-blog-2%7Edefault%7EBlogOpenSearchComplete%7ERate-5-46821953-blog-71158962.235%5Ev43%5Epc_blog_bottom_relevance_base8&utm_relevant_index=10
进入嵌入式查看更多内容>>
相关视频
  • 【TI MSPM0 应用实战】智能小车+工业角度编码器+血氧仪+烟雾探测器!硬核参考设计详解!
  • FollowMe 第二季:3 - EK_RA6M5 开发板入门
  • FollowMe 第二季: 1 Adafruit Circuit Playground Express及任务讲解
  • Azure RTOS step by step workshop
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • 从0到1:树莓派与物联网教程(英文)
精选电路图
  • 设计汽车集群电源
  • 6晶体管H桥
  • USB自供电声卡
  • AVR LCD温度计—LM35
  • AVR PC步进电机驱动器
  • AVR温度计TCN75
    相关电子头条文章
