单片机
(8)趣味单片机新玩法-多个数码管扫描显示
2025-03-25 来源:jianshu
我们先来看第一个效果,数码管以秒计数显示
动态效果图
老套路,我们接下来进行分解,我们首先第一步就是让每个数码管都可控,不知道怎么使用74HC595的可以参考之前写的文章
代码:
/* Main.ino file generated by New Project wizard
 * Created:   周六 3月 20 2021
 * Processor: Arduino Uno
 * Compiler:  Arduino AVR (Proteus)
 */// Peripheral Configuration Code (do not edit)//---CONFIG_BEGIN---#pragma GCC push_options#pragma GCC optimize ('Os')#include // Required by cpu#include #pragma GCC pop_options// Peripheral ConstructorsCPU &cpu = Cpu;void peripheral_setup () {}void peripheral_loop() {}//---CONFIG_END---int STCP_Pin = 6;int SHCP_Pin = 4;int DS_Pin = 5;
 char table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};void setup () {peripheral_setup();// TODO: put your setup code here, to run once:
    pinMode(STCP_Pin,OUTPUT);
    pinMode(SHCP_Pin,OUTPUT);
    pinMode(DS_Pin,OUTPUT);}void loop() {peripheral_loop();// TODO: put your main code here, to run repeatedly:
    digitalWrite(STCP_Pin,LOW);
    shiftOut(DS_Pin,SHCP_Pin,MSBFIRST, 0xDF);
    shiftOut(DS_Pin,SHCP_Pin,MSBFIRST, table[0]);
    digitalWrite(STCP_Pin,HIGH);
    delay(500);
    shiftOut(DS_Pin,SHCP_Pin,MSBFIRST, 0xEF);
    shiftOut(DS_Pin,SHCP_Pin,MSBFIRST, table[1]);
    delay(500);
    shiftOut(DS_Pin,SHCP_Pin,MSBFIRST, 0xF7);
    shiftOut(DS_Pin,SHCP_Pin,MSBFIRST, table[2]);
    delay(500);
    shiftOut(DS_Pin,SHCP_Pin,MSBFIRST, 0xFB);
    shiftOut(DS_Pin,SHCP_Pin,MSBFIRST, table[3]);
    delay(500);
    shiftOut(DS_Pin,SHCP_Pin,MSBFIRST, 0xFD);
    shiftOut(DS_Pin,SHCP_Pin,MSBFIRST, table[4]);
    delay(500);
    shiftOut(DS_Pin,SHCP_Pin,MSBFIRST, 0xFE);
    shiftOut(DS_Pin,SHCP_Pin,MSBFIRST, table[5]);
    delay(500);}
我们接下来把速度提一提,延时改成50ms
感觉还是有点慢,我们再提点速度,改成10ms
但是,感觉显示有点乱,我们尝试在每个数码管显示过后给它关闭,在电视机邻域有个专业的名词叫消隐
    delay(10);
    // 消隐
    shiftOut(DS_Pin,SHCP_Pin,MSBFIRST, 0xFF);
    shiftOut(DS_Pin,SHCP_Pin,MSBFIRST, 0x00);
    delay(1);
我们再来看下效果,是不是没有乱码了,之前因为没有关闭,由于人眼的余晖效应,会造成乱码
然后我们稍微再提点速度≥50Hz的刷新率,6个数码管,每个耗时3ms,这样整个下来的总时间是18ms,基本上就不会看到闪烁。
    delay(2);
    // 消隐
    delay(1);
18ms刷新的效果,基本看不到闪烁的变化
文章开头效果总代码:
    pinMode(DS_Pin,OUTPUT);}int count = 0;int sec = 0;void loop() {peripheral_loop();
    count++;
    if(count>50)
        count=0;
        sec++;
        if(sec>10)sec=0;
        shiftOut(DS_Pin,SHCP_Pin,MSBFIRST, table[sec]);
        delay(2);
        // 消隐
        delay(1);
        delay(2);
        delay(1);
        delay(2);
        delay(1);
        delay(2);
        delay(1);
        delay(2);
        delay(1);
        delay(2);
        delay(1);}
总结
复杂的原理来自多年实验的总结,同样也来自生活实践。
进入单片机查看更多内容>>
相关视频
  • 【TI MSPM0 应用实战】智能小车+工业角度编码器+血氧仪+烟雾探测器!硬核参考设计详解!
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
  • 直播回放: Microchip Timberwolf™ 音频处理器在线研讨会
  • 基于灵动MM32W0系列MCU的指夹血氧仪控制及OTA升级应用方案分享
精选电路图
  • 便携式混音器
  • 18W乙类音频放大器
  • 6晶体管H桥
  • USB LED调光器
  • USB自供电声卡
  • AVR LCD温度计—LM35
    相关电子头条文章
