单片机
《逗比小憨憨51单片机Proteus仿真系列》第15期基于单片机的LCD12864显示图片实验
2025-10-31 来源:bilibili
源代码:
#include <reg52.h>
#include <intrins.h>
#define LcdDataPort P2
typedef unsigned char u8;
typedef unsigned int u16;
sbit Busy = P2^7;
sbit Reset = P3^0;
sbit RS = P3^1;
sbit E = P3^2;
sbit RW = P3^3;
sbit CS1 = P3^4;
sbit CS2 = P3^5;
const u8 code table1[] = {
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0x3F,0x1F,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,
0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,
0xFF,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xF0,0xE0,0xC7,0x8F,0x1F,0x3F,0x7F,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFC,0x00,0x01,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE7,0xE0,0xE0,
0xFF,0xFC,0xF8,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,
0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,
0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0xCF,0x1F,0x3F,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x00,0x00,0xFF,
0xFF,0xFF,0x7F,0x3F,0x1F,0x8F,0xC7,0xE0,0xF0,0xF8,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0x01,0x00,0xFC,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xE0,0xE0,0xE7,0xFF,0xFF,0xE7,0xE7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF3,0xF8,0xFC,0xFF,
void delay_ms(u16 xms);
void Check_Busy(void);
void Write_Command(u8 command);
void Write_Data(u8 dat);
void Select_Screen(u8 screen);
void Set_Line(u8 line);
void Set_Columm(u8 columm);
void Set_StartLine(u8 startline);
void Clear_Screen(u8 screen);
void On_Off(u8 onoff);
void Lcd_Reset(void);
void Show_6464(u8 line,u8 columm,u8 *address);
void Lcd_Init(void);
void main(void)
u8 i,line,columm;
u8 *address;
Lcd_Init();
while(1)
line = 0;
columm = 0;
address = table1;
On_Off(0);
for(i=1;i<3;i++)
if(i<2)
Select_Screen(1);
else Select_Screen(2);
Show_6464(line,columm,address);
columm += 64;
if(columm>63)
columm = 0;
address += 512;
Select_Screen(0);
On_Off(1);
delay_ms(100000);
E = 1;
RS = 0;
RW = 1;
LcdDataPort = 0xff;
while(!Busy);
Check_Busy();
E = 1;
RS = 0;
RW = 0;
LcdDataPort = command;
E = 0;
_nop_();
Check_Busy();
E = 1;
RS = 1;
RW = 0;
LcdDataPort = dat;
E = 0;
_nop_();
switch(screen)
case 0:
CS1 = 0;
_nop_();
CS2 = 0;
_nop_();
break;
case 1:
CS1 = 0;
_nop_();
CS2 = 1;
_nop_();
break;
case 2:
CS1 = 1;
_nop_();
CS2 = 0;
_nop_();
break;
case 3:
CS1 = 1;
_nop_();
CS2 = 1;
_nop_();
break;
line = line & 0x07;
line = line | 0xb8;
Write_Command(line);
columm = columm & 0x3f;
columm = columm | 0x40;
Write_Command(columm);
startline = startline & 0x3f;
startline = startline | 0xc0;
Write_Command(startline);
u8 x,y;
Select_Screen(screen);
for(x=0;x<8;x++)
Set_Line(x);
Set_Columm(0);
for(y=0;y<64;y++)
Write_Data(0);
if(onoff == 1)
Write_Command(0x3f);
else Write_Command(0x3e);
void Lcd_Reset()
Reset = 0;
delay_ms(5);
Reset = 1;
delay_ms(5);
On_Off(1);
void Lcd_Init()
Lcd_Reset();
On_Off(0);
Clear_Screen(0);
Set_Line(0);
Set_Columm(0);
Set_StartLine(0);
On_Off(1);
u8 i;
Set_Line(line);
Set_Columm(columm);
for(i=0;i<64;i++)
Write_Data(*(address++));
Set_Line(line+1);
Set_Columm(columm);
for(i=0;i<64;i++)
Set_Line(line+2);
Set_Columm(columm);
for(i=0;i<64;i++)
Set_Line(line+3);
Set_Columm(columm);
for(i=0;i<64;i++)
Set_Line(line+4);
Set_Columm(columm);
for(i=0;i<64;i++)
Set_Line(line+5);
Set_Columm(columm);
for(i=0;i<64;i++)
Set_Line(line+6);
Set_Columm(columm);
for(i=0;i<64;i++)
Set_Line(line+7);
Set_Columm(columm);
for(i=0;i<64;i++)
u16 x,y;
for(x=xms;x>0;x--)
for(y=125;y>0;y--);
进入单片机查看更多内容>>
相关视频
  • 【TI MSPM0 应用实战】智能小车+工业角度编码器+血氧仪+烟雾探测器!硬核参考设计详解!
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
  • 直播回放: Microchip Timberwolf™ 音频处理器在线研讨会
  • 基于灵动MM32W0系列MCU的指夹血氧仪控制及OTA升级应用方案分享
精选电路图
  • 锂离子/锂聚合物USB电池充电器
  • 6晶体管H桥
  • AVR LCD温度计—LM35
  • AVR PC步进电机驱动器
  • AVR温度计TCN75
  • JDM2 PIC 18F 编程器
    相关电子头条文章
