u-boot-2011.03在mini2440/micro2440上的移植 支持Nand Flash启动
2024-07-01 来源:elecfans
7.1 创建nand_read.c
【注意】
本程序只能用于读取2K/页的Nand。本人的Micro2440上的Nand Flash为256M,型号为K9F2G08
[www.linuxidc.com@linuxidc u-boot-2011.06]$ touch board/samsung/micro2440/nand_read.c
[www.linuxidc.com@linuxidc u-boot-2011.06]$ cat> board/samsung/micro2440/nand_read.c
#define rNFCONF (*(volatile unsigned *)0x4E000000)
#define rNFCONT (*(volatile unsigned *)0x4E000004)
#define rNFCMD (*(volatile unsigned *)0x4E000008)
#define rNFADDR (*(volatile unsigned *)0x4E00000C)
#define rNFDATA8 (*(volatile unsigned char*)0x4E000010)
#define rNFSTAT (*(volatile unsigned *)0x4E000020)
#define CMD_READ1 0x00 /* 页读命令周期1 */
#define CMD_READ2 0x30 /* 页读命令周期2 */
#define CMD_RESET 0xFF /* 复位 */
#define NF_CMD(cmd) {rNFCMD=(cmd);} /* 写命令 */
#define NF_ADDR(addr) {rNFADDR=(addr);} /* 写地址 */
#define NF_RDDATA8() (rNFDATA8) /* 读8位数据 */
#define NF_nFCE_L() {rNFCONT&=~(1<<1);} /* 片选使能 */
#define NF_nFCE_H() {rNFCONT|=(1<<1);} /* 片选禁用 */
#define NF_WAITRB() {while(!(rNFSTAT&(1<<1)));} /* 等待就绪 */
#define NF_CLEAR_RB() {rNFSTAT |= (1<<2);} /* 清除就绪/忙位 */
#define NF_DETECT_RB() {while(!(rNFSTAT&(1<<2)));} /* 等待就绪 */
#define TACLS 1
#define TWRPH0 2
#define TWRPH1 1
void delay(int i)
while(i-->0);
void Nand_Init(void)
rNFCONF = (TACLS<<12)|(TWRPH0<<8)|(TWRPH1<<4)|(0<<0);
rNFCONT = (1<<4)|(1<<1)|(1<<0);
static void Nand_Reset(void)
NF_nFCE_L(); /* 片选使能 */
NF_CLEAR_RB(); /* 清除就绪/忙位 */
NF_CMD(CMD_RESET); /* 写复位命令 */
NF_DETECT_RB(); /* 等待就绪 */
NF_nFCE_H(); /* 片选禁用 */
unsigned char Nand_ReadPage(const int page, unsigned char * const buffer)
int i;
Nand_Reset();
NF_nFCE_L();
NF_CLEAR_RB();
NF_CMD(CMD_READ1);
NF_ADDR(0x0);
NF_ADDR(0x0);
NF_ADDR(page&0xff);
NF_ADDR((page>>8)&0xff);
NF_ADDR((page>>16)&0xff);
NF_CMD(CMD_READ2);
NF_DETECT_RB();
for (i = 0; i < 2048; i++)
buffer[i] = NF_RDDATA8();
NF_nFCE_H();
int nand_read(int start_page, int read_pages, unsigned char *buffer)
int i;
Nand_Init();
for(i=0; i
Nand_ReadPage(start_page, buffer + 2048*i);
start_page++;
return 0;
7.2 board/samsung/micro2440/Makefile
COBJS := micro2440.o flash.o nand_read.o
7.3 arch/arm/cpu/arm920t/u-boot.lds
.text :
arch/arm/cpu/arm920t/start.o (.text)
board/samsung/micro2440/libmicro2440.o (.text)
*(.text)
【说明】
如果是在RAM中运行,一定要删去board/samsung/micro2440/libmicro2440.o (.text),否则在RAM中也不能运行。原因尚不理解,需要阅读代码。
7.4 arch/arm/cpu/arm920t/start.S
下面红色部分是添加的部分,黑色的代码用于定位。
#ifndef CONFIG_SKIP_LOWLEVEL_INIT
bl cpu_init_crit
#endif
#ifdef CONFIG_S3C2440_NAND_BOOT
ldr sp, =0x30008000
ldr r0, =0x0;
ldr r1, _end_ofs
mov r1, r1, LSR #11
add r1, r1, #1
ldr r2, =(CONFIG_SYS_TEXT_BASE)
bl nand_read
ldr pc, =relocations
#endif
copy_loop:
ldmia r0!, {r9-r10} /* copy from source address [r0] */
stmia r1!, {r9-r10} /* copy to target address [r1] */
cmp r0, r2 /* until source end address [r2] */
blo copy_loop
relocations:
ldr r6, =CONFIG_SYS_TEXT_BASE
#endif
#ifndef CONFIG_PRELOADER
* fix .rel.dyn relocations
clbss_l:str r2, [r0] /* clear loop... */
add r0, r0, #4
cmp r0, r1
bne clbss_l
bl coloured_LED_init
bl red_LED_on
#endif
ldr sp, =(CONFIG_SYS_INIT_SP_ADDR)
bic sp, sp, #7 /* 8-byte alignment for ABI compliance */
ldr r0,=0x00000000
ldr pc, =board_init_f
#endif
* We are done. Do not return, instead branch to second part of board
* initialization, now running from RAM.
#ifdef CONFIG_NAND_SPL
7.5 include/configs/micro2440.h
#define CONFIG_S3C2440_NAND_BOOT /* #define CONFIG_SKIP_LOWLEVEL_INIT */
【说明】
由于要在Nand Flash中运行,所以需要注释掉#define CONFIG_SKIP_LOWLEVEL_INIT
7.6 arch/arm/lib/board.c
void board_init_f (ulong bootflag)
gd->mon_len = _bss_end_ofs + 0x100000; /* why */
这里的修改参考了bscbem的日志:http://www.linuxidc.com/Linux/2011-02/32772p4.htm
如果有读者想了解原理请参考这个日志。
/* relocate_code (addr_sp, id, addr); */ #ifdef CONFIG_S3C2440_NAND_BOOT /*add by wzc*/ __asm__ __volatile__('mov sp,%0'::'r'(addr_sp):'sp');/*add by wzc*/ board_init_r(id, addr); #else relocate_code (addr_sp, id, addr); /* NOTREACHED - relocate_code() does not return */ #endif }【说明】至于gd->mon_len = _bss_end_ofs + 0x100000;我也不理解,需要阅读源代码才能解释。
7.7 下载到Nand Flash
到这里应该就可以从Nand Flash启动了。
- 【IMX6ULL学习笔记】三、U-BOOT Makefile详解
- 【IMX6ULL学习笔记】五、U-BOOT移植与解析
- 【IMX6ULL学习笔记】六、U-BOOT环境变量与Linux启动
- [国嵌笔记][028][Bootloader设计蓝图]
- IMX6ULL学习笔记(5)——获取和编译U-Boot
- IMX6ULL学习笔记(6)——通过USB OTG烧录U-Boot(MfgTool工具)
- IMX6ULL学习笔记(7)——通过SD卡启动U-Boot
- [国嵌笔记][030][U-Boot工作流程分析]
- 分析u-boot的Makefile
- Tiny210 U-BOOT(二)----配置时钟频率基本原理
- 六大全新产品系列推出,MCX A微控制器家族迎来创新
- 意法半导体全新STM32C5系列,重新定义入门级微控制器性能与价值,赋能万千智能设备
- 模组复用与整机重测在SRRC、CCC、CTA/NAL认证中的实践操作指南
- 有源晶振与无源晶振的六大区别详解
- 英飞凌持续巩固全球微控制器市场领导地位
- 使用 Keil Studio for Visual Studio Code开发 STM32 设备
- 从控制到系统:TI利用边缘AI重塑嵌入式MCU的边界
- 蓝牙信道探测技术原理与开发套件实践
- Microchip 推出生产就绪型全栈边缘 AI 解决方案,赋能MCU和MPU实现 智能实时决策
- LoRa、LoRaWAN、NB-IoT与4G DTU技术对比及工业无线方案选型分析
