【IMX6ULL学习笔记】八、Linux启动流程
2025-03-03 来源:elecfans
一、链接脚本 vmlinux.lds
Linux 内核的链接脚本文件 arch/arm/kernel/vmlinux.lds 中有如下代码:
ENTRY 指明了了 Linux 内核入口,入口为 stext,stext 定义在文件 arch/arm/kernel/head.S 中。
二、Linux 内核启动流程分析
1、Linux 内核入口 stext
stext 是 Linux 内核的入口地址,在文件 arch/arm/kernel/head.S 中有如下所示提示内容:
* Kernel startup entry point.
* This is normally called from the decompressor code. The requirements
* are: MMU = off, D-cache = off, I-cache = dont care, r0 = 0,
* r1 = machine nr, r2 = atags or dtb pointer.
Linux 内核启动之前要求如下:
①、关闭 MMU。
②、关闭 D-cache。
③、I-Cache 无所谓。
④、r0=0。
⑤、r1=machine nr(也就是机器 ID)。
⑥、r2=atags 或者设备树(dtb)首地址。
Linux 内核的入口点 stext 其实相当于内核的入口函数,stext 函数内容如下:
80 ENTRY(stext)
91 @ ensure svc mode and all interrupts masked
92 safe_svcmode_maskall r9
93
94 mrc p15, 0, r9, c0, c0 @ get processor id
95 bl __lookup_processor_type @ r5=procinfo r9=cpuid
96 movs r10, r5 @ invalid processor (r5=0)?
97 THUMB( it eq ) @ force fixup-able long branch encoding
98 beq __error_p @ yes, error 'p'
99
107
108 #ifndef CONFIG_XIP_KERNEL
113 #else
114 ldr r8, =PLAT_PHYS_OFFSET @ always constant in this case
115 #endif
116
117 /*
118 * r1 = machine no, r2 = atags or dtb,
119 * r8 = phys_offset, r9 = cpuid, r10 = procinfo
120 */
121 bl __vet_atags
128 bl __create_page_tables
129
130 /*
131 * The following calls CPU specific code in a position independent
132 * manner. See arch/arm/mm/proc-*.S for details. r10 = base of
133 * xxx_proc_info structure selected by __lookup_processor_type
134 * above. On return, the CPU will be ready for the MMU to be
135 * turned on, and r0 will hold the CPU control register value.
136 */
137 ldr r13, =__mmap_switched @ address to jump to after
138 @ mmu has been enabled
139 adr lr, BSYM(1f) @ return (PIC) address
140 mov r8, r4 @ set TTBR1 to swapper_pg_dir
141 ldr r12, [r10, #PROCINFO_INITFUNC]
142 add r12, r12, r10
143 ret r12
144 1: b __enable_mmu
145 ENDPROC(stext)
第 92 行:调用函数 safe_svcmode_maskall 确保 CPU 处于 SVC 模式,并关闭所有中断,定义arch/arm/include/asm/assembler.h 中。
第 94 行:读处理器 ID,ID 值保存在 r9 寄存器中。
第 95 行:调用函数__lookup_processor_type 检查当前系统是否支持此 CPU,如果支持就获取 procinfo 信息。 procinfo 是 proc_info_list 类型的结构体,在 arch/arm/include/asm/procinfo.h 中的定义如下:
struct proc_info_list {
unsigned int
cpu_val;
unsigned int cpu_mask;
unsigned long __cpu_mm_mmu_flags; /* used by head.S */
unsigned long __cpu_io_mmu_flags; /* used by head.S */
unsigned long __cpu_flush; /* used by head.S */
const char
*arch_name;
const char
*elf_name;
unsigned int elf_hwcap;
const char
*cpu_name;
struct processor *proc;
struct cpu_tlb_fns *tlb;
struct cpu_user_fns *user;
struct cpu_cache_fns *cache;
Linux 内核将每种处理器都抽象为一个 proc_info_list 结构体,每种处理器都对应一个procinfo。因此可以通过处理器 ID 来找到对应的 procinfo 结构,__lookup_processor_type 函数找到对应处理器的 procinfo 以后会将其保存到 r5 寄存器中。
第 121 行:调用函数__vet_atags 验证 atags 或设备树(dtb)的合法性。函数__vet_atags 定义在文件 arch/arm/kernel/head-common.S 中。
第 128 行:调用函数__create_page_tables 创建页表。
第 137 行:将函数__mmap_switched 的地址保存到 r13 寄存器中。定义在文件 arch/arm/kernel/head-common.S中,函数__mmap_switched 最终会调用 start_kernel 函数。
第 144 行:调用__enable_mmu函数使能 MMU ,__enable_mmu 定义在文件 arch/arm/kernel/head.S 中。__enable_mmu 会通过调用__turn_mmu_on来打开 MMU,__turn_mmu_on 最后会执行 r13 里面保存的__mmap_switched 函数。
2、__mmap_switched 函数
__mmap_switched 函数定义在文件 arch/arm/kernel/head-common.S 中,最终调用 start_kernel 来启动 Linux 内核。
3、start_kernel 函数
start_kernel 函数定义在文件 init/main.c 中。start_kernel 里面调用了大量的函数来启动 Linux 内核,最后调用了 rest_init。
4、rest_init 函数
rest_init 函数定义在文件 init/main.c 中,函数内容如下:
383 static noinline void __init_refok rest_init(void)
384 {
385 int pid;
386
387 rcu_scheduler_starting();
388 smpboot_thread_init();
389 /*
390 * We need to spawn init first so that it obtains pid 1, however
391 * the init task will end up wanting to create kthreads, which,
392 * if we schedule it before we create kthreadd, will OOPS.
393 */
394 kernel_thread(kernel_init, NULL, CLONE_FS);
395 numa_default_policy();
396 pid = kernel_thread(kthreadd, NULL, CLONE_FS | CLONE_FILES);
397 rcu_read_lock();
398 kthreadd_task = find_task_by_pid_ns(pid, &init_pid_ns);
399 rcu_read_unlock();
400 complete(&kthreadd_done);
401
402 /*
403 * The boot idle thread must execute schedule()
404 * at least once to get things moving:
405 */
406 init_idle_bootup_task(current);
407 schedule_preempt_disabled();
408 /* Call into cpu_idle with preempt disabled */
409 cpu_startup_entry(CPUHP_ONLINE);
410 }
第 387 行:调用函数 rcu_scheduler_starting,启动 RCU 锁调度器
第 394 行:调用函数 kernel_thread 创建 kernel_init 进程,也就是 init 内核进程。init 进程的 PID 为 1。
第 396 行:调用函数 kernel_thread 创建 kthreadd 内核进程,此内核进程的 PID 为 2。kthreadd 进程负责所有内核进程的调度和管理。
第 409 行:最后调用函数 cpu_startup_entry 来进入 idle 进程。
在 Linux 终端中输入“ps -A”就可以打印出当前系统中的所有进程
5、init 进程
kernel_init 函数就是 init 进程具体做的工作,定义在文件 init/main.c 中,函数内容如下:
928 static int __ref kernel_init(void *unused)
929 {
930 int ret;
931
932 kernel_init_freeable(); /* init 进程的一些其他初始化工作 */
933 /* need to finish all async __init code before freeing the memory */
934 async_synchronize_full(); /* 等待所有的异步调用执行完成 */
935 free_initmem(); /* 释放 init 段内存 */
936 mark_rodata_ro();
937 system_state = SYSTEM_RUNNING; /* 标记系统正在运行 */
938 numa_default_policy();
939
940 flush_delayed_fput();
941
942 if (ramdisk_execute_command) {
943 ret = run_init_process(ramdisk_execute_command);
944 if (!ret)
945 return 0;
946 pr_err('Failed to execute %s (error %d)n',
947 ramdisk_execute_command, ret);
948 }
949
950 /*
951 * We try each of these until one succeeds.
952 *
953 * The Bourne shell can be used instead of init if we are
954 * trying to recover a really broken machine.
955 */
956 if (execute_command) {
957 ret = run_init_process(execute_command);
958 if (!ret)
959 return 0;
960 panic('Requested init %s failed (error %d).',
961 execute_command, ret);
962 }
963 if (!try_to_run_init_process('/sbin/init') ||
964 !try_to_run_init_process('/etc/init') ||
965 !try_to_run_init_process('/bin/init') ||
966 !try_to_run_init_process('/bin/sh'))
967 return 0;
968
969 panic('No working init found. Try passing init= option to kernel. '
970 'See Linux Documentation/init.txt for guidance.');
971 }
第 932 行:kernel_init_freeable 用于完成 init 进程的一些初始化工作。
第 940 行:ramdisk_execute_command 是一个全局的 char 指针变量,此变量值为“/init”,也就是根目录下的 init 程序。ramdisk_execute_command 也可以通过 uboot 传递,在 bootargs 中使用“rdinit=xxx”即可,xxx 为具体的 init 程序名字。
第 943 行:如果存在“/init”程序就通过函数 run_init_process 运行此程序。
第 956 行:如果 ramdisk_execute_command 为空就看 execute_command 是否为空,不管如何一定要在根文件系统中找到一个 init 程序。execute_command 的值是通过 uboot 传递,在 bootargs 中用“init=xxxx”就可以了,比如 “init=/linuxrc” 表示根文件系统中的 linuxrc 为要执行的用户空间init程序。
第 963~966 行:如果 ramdisk_execute_command 和 execute_command 都为空,那么就依次查找“/sbin/init”、“/etc/init”、“/bin/init”和“/bin/sh”,这四个相当于备用 init 程序,如果这四个也不存在,那么 Linux 启动失败!
第 969 行:如果以上步骤都没有找到用户空间的 init 程序,那么就提示错误发生!
kernel_init_freeable 定义在文件 init/main.c 中,缩减后内容如下:
973 static noinline void __init kernel_init_freeable(void)
974 {
975 /*
976 * Wait until kthreadd is all set-up.
977 */
978 wait_for_completion(&kthreadd_done);/* 等待 kthreadd 进程准备就绪 */
998
999 smp_init(); /* SMP 初始化 */
1000 sched_init_smp(); /* 多核(SMP)调度初始化 */
1001
1002 do_basic_setup(); /* 设备初始化都在此函数中完成 */
1003
1004 /* Open the /dev/console on the rootfs, this should never fail */
1005 if (sys_open((const char __user *) '/dev/console', O_RDWR, 0) < 0)
1006 pr_err('Warning: unable to open an initial console.n');
1007
1008 (void) sys_dup(0);
1009 (void) sys_dup(0);
1010 /*
1011 * check if there is an early userspace init. If yes, let it do
1012 * all the work
1013 */
1014
1015 if (!ramdisk_execute_command)
1016 ramdisk_execute_command = '/init';
1017
1018 if (sys_access((const char __user *) ramdisk_execute_command, 0) != 0) {
1019 ramdisk_execute_command = NULL;
1020 prepare_namespace();
1021 }
1022
1023 /*
1024 * Ok, we have completed the initial bootup, and
1025 * we're essentially up and running. Get rid of the
1026 * initmem segments and start the user-mode stuff..
1027 *
1028 * rootfs is available now, try loading the public keys
1029 * and default modules
1030 */
1031
1032 integrity_load_keys();
1033 load_default_modules();
1034 }
第 1002 行:do_basic_setup 函数用于完成 Linux 下设备驱动初始化工作,非常重要!do_basic_setup 会调用 driver_init 函数完成 Linux 下驱动模型子系统的初始化。
第 1005 行:打开设备“/dev/console”,在 Linux 中一切皆为文件!因此 “/dev/console” 也是一个文件,此文件为控制台设备。每个文件都有一个文件描述符,此处打开的 “/dev/console” 文件描述符为 0,作为标准输入(0)。
第 1008 和 1009 行:sys_dup 函数将标准输入(0)的文件描述符复制了 2 次,一个作为标准输出(1),一个作为标准错误(2)。这样标准输入、输出、错误都是 /dev/console 了。console 通过 uboot 的 bootargs 环境变量设置, “console=ttymxc0,115200” 表示将 /dev/ttymxc0 设置为 console,也就是 I.MX6U 的串口 1。当然,也可以设置其他的设备为 console,如虚拟控制台tty1,设置 tty1 为 console 就可以在 LCD 屏幕上看到系统的提示信息。
第 1020 行:调用函数 prepare_namespace 来挂载根文件系统。根文件系统也是由命令行参数指定的,即 bootargs 环境变量。比如“root=/dev/mmcblk1p2 rootwait rw”就表示根文件系统在/dev/mmcblk1p2 中,也就是 EMMC 的分区 2 中。
- 六大全新产品系列推出,MCX A微控制器家族迎来创新
- 意法半导体全新STM32C5系列,重新定义入门级微控制器性能与价值,赋能万千智能设备
- 从控制到系统:TI利用边缘AI重塑嵌入式MCU的边界
- 模组复用与整机重测在SRRC、CCC、CTA/NAL认证中的实践操作指南
- 有源晶振与无源晶振的六大区别详解
- 英飞凌持续巩固全球微控制器市场领导地位
- 使用 Keil Studio for Visual Studio Code开发 STM32 设备
- LoRa、LoRaWAN、NB-IoT与4G DTU技术对比及工业无线方案选型分析
- 意法半导体中国本地造STM32微控制器启动规模量产
- 蓝牙信道探测技术原理与开发套件实践
