单片机
GD32F310开发板串口的数据接收与数字自动转换
2024-12-05 来源:elecfans
串口的功能网上有很多,但是处理串口的数据需要一些小手段,但是str的函数有点才长,不适用长的数据接收,所以给310搞一个接收数据的轻量级API的小玩意。
开发环境
Keil-MDK 5.34
Windows10
固件库-GD32F3x0_Firmware_Library_V2.2.0
新建工程就不赘述,看这个
启动串口
void uart_init(void)
    //使能时钟
    rcu_periph_clock_enable(RCU_GPIOA);
    rcu_periph_clock_enable(RCU_USART0);
    //Tx PA9 复用推挽输出
    gpio_mode_set(GPIOA,GPIO_MODE_AF,GPIO_PUPD_PULLUP,GPIO_PIN_9);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_9);
    //Rx    PA10
    gpio_mode_set(GPIOA,GPIO_MODE_AF,GPIO_PUPD_PULLUP,GPIO_PIN_10);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP,GPIO_OSPEED_50MHZ, GPIO_PIN_10);
    nvic_irq_enable(USART0_IRQn,0,0);
    gpio_af_set(GPIOA,GPIO_AF_1,GPIO_PIN_9|GPIO_PIN_10);
    /*USART 设置*/
    usart_deinit(USART0);
    usart_baudrate_set(USART0,115200);
    usart_word_length_set(USART0,USART_WL_8BIT);
    usart_stop_bit_set(USART0,USART_STB_1BIT);
    usart_parity_config(USART0,USART_PM_NONE);
    usart_hardware_flow_rts_config(USART0,USART_RTS_DISABLE);
    usart_hardware_flow_cts_config(USART0,USART_CTS_DISABLE);
    usart_receive_config(USART0,USART_RECEIVE_ENABLE);
    usart_transmit_config(USART0,USART_TRANSMIT_ENABLE);
    usart_enable(USART0);
    usart_interrupt_enable(USART0,USART_INT_RBNE);
    usart_interrupt_enable(USART0, USART_INT_IDLE);         /* 使能USART0空闲中断 */
//串口中断配置
uint16_t t=0;
void USART0_IRQHandler(void)
    if(RESET!=usart_interrupt_flag_get(USART0,USART_INT_FLAG_RBNE))
        gd_led_toggle();
        t=usart_data_receive(USART0);//接收数据
        usart_data_transmit(USART0,USART_RX[t]);
        usart_interrupt_disable(USART0,USART_INT_RBNE);
        usart_data_transmit(USART0,t);
    }else if(RESET!=usart_interrupt_flag_get(USART0,USART_INT_FLAG_IDLE))
        usart_interrupt_disable(USART0,USART_INT_IDLE);
数据处理API
struct _Chang_Num
    char *Source;
    char Sign[8];
    float NUM[8];
    char flag;
char Data_Chang_NUM (struct _Chang_Num *Item)
    char Data_Array[12] = {0};                  //数字的str数
    char str[36];                               //装source数据到这个缓存区,这个缓存区是要变的
    char Data;
    char n,m = 0;
    char i,flag = 1;                            //i是当前找的是 第几个 Sign
    char Find_Time = strlen(Item->Sign);        //要找多少个
    char Length = strlen(Item->Source);         //源的长度
    strcpy(str,Item->Source);
    if(Length > 36)
        Length = 36;
    for (i = 0; i < Find_Time; i++)
        flag = 0;
        for(n = 0;n < Length;n++)
            Data = str[n];
            if(str[n] == Item->Sign[i])           //找到标志
                str[n] = 0;
                flag = 1;                       //开始识别str
                m = 0;
            if(flag)
                if((str[n] <= '9' && str[n] >= '0') || str[n] == '.' || str[n] == '-')
                    Data_Array[m] = str[n];               //把数字相关str的装起来
                    m++;                                //m是数字在str的长度
                else
                    if(m > 0)                            //数字部分结束
                        if(Data_Array[m-1] == '.' || Data_Array[m-1] == '-')    //不让最后一位为 '.' and '-'
                            Data_Array[m-1] = '';
                        else
                            Data_Array[m] = '';
                        break;
        Item->NUM[i] = atof(Data_Array);
        // Data_Replace ('123',Data_Array,0,sizeof(Data_Array));
    return Item->flag;
配置好你想要的参数在结构体中,然后将串口的缓冲区放入这个函数即可。
将printf函数映射到串口,看这里
struct _Chang_Num Item_n = {
    .Source = 'a:3.14......,b:3322..,c:-9.0..-',
    .Sign = {':',':',':'},
int main (void)
    printf('sign :%s',Item_n.Sign);
    Data_Chang_NUM (&Item_n);
    for (char i = 0; i < 3; i++)
        printf('num %d :%.2f n',i,Item_n.NUM[i]);
    while(1);
API效果
进入单片机查看更多内容>>
相关视频
  • 【TI MSPM0 应用实战】智能小车+工业角度编码器+血氧仪+烟雾探测器!硬核参考设计详解!
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
  • 直播回放: Microchip Timberwolf™ 音频处理器在线研讨会
  • 基于灵动MM32W0系列MCU的指夹血氧仪控制及OTA升级应用方案分享
精选电路图
  • 1瓦线性调频增强器
  • 1瓦四级调频发射机
  • 500W MOS场效应管电源逆变器,12V转110V/220V
  • 红外开关
  • LM317过压保护
  • 0-30V/20A 大功率稳压电源(采用LM338)
    相关电子头条文章
