GD32F310连接ESP8266实现远程灯控制
2024-12-06 来源:elecfans
功能描述
通过mcu与esp01通过uart连接,通过at指令来创建socket连接,接收远端控制灯的指令,来实现灯亮,灭及闪烁;
开启两路串口,usart0(GPIO09-TX,GPIO10-RX)连接esp01,进行收发at指令,usart1(GPIO02-TX,GPIO03-RX)作为log输出口;
接线图
ps.电阻可以不接,直接EN和3.3V拉一根线也能起来;
有条件的话,可以选esp01s,不用接电阻。
代码流程介绍
uart0连接esp01,收发数据使用中断方式进行,接收数据检测到OK,ERROR等关键字以后关闭接收。
uart中断
void USART0_IRQHandler(void) {
if(RESET != usart_interrupt_flag_get(USART0, USART_INT_FLAG_RBNE)) {
/* receive data */
rx_buffer[rx_count++] = usart_data_receive(USART0);
if(rx_count >= BUFFER_SIZE) {
usart_interrupt_disable(USART0, USART_INT_RBNE);
printf('rx buffer is full!!n');
recv_flag = 0;
if(strstr((const char *)rx_buffer, 'OKrn') ||
strstr((const char *)rx_buffer, 'ERRORrn')
recv_flag = 0;
else if(strstr((const char *)rx_buffer, 'blink') ||
strstr((const char *)rx_buffer, 'on') ||
strstr((const char *)rx_buffer, 'off')
recv_flag = 0;
if(RESET != usart_interrupt_flag_get(USART0, USART_INT_FLAG_TBE)) {
/* transmit data */
usart_data_transmit(USART0, tx_buffer[tx_count++]);
if(tx_count >= BUFFER_SIZE) {
usart_interrupt_disable(USART0, USART_INT_TBE);
send_flag = 0;
if(tx_count >= send_len)
send_flag = 0;
send_len = 0;
uart初始化:
/* enable COM GPIO clock */
rcu_periph_clock_enable(RCU_GPIOA);
/* connect port to USARTx_Tx */
gpio_af_set(GPIOA, GPIO_AF_1, GPIO_PIN_9);
/* connect port to USARTx_Rx */
gpio_af_set(GPIOA, GPIO_AF_1, GPIO_PIN_10);
/* configure USART Tx as alternate function push-pull */
gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_9);
gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, GPIO_PIN_9);
/* configure USART Rx as alternate function push-pull */
gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_10);
gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, GPIO_PIN_10);
/* enable USART clock */
rcu_periph_clock_enable(RCU_USART0);
/* USART configure */
usart_deinit(USART0);
usart_baudrate_set(USART0, 115200U);
usart_receive_config(USART0, USART_RECEIVE_ENABLE);
usart_transmit_config(USART0, USART_TRANSMIT_ENABLE);
usart_enable(USART0);
nvic_irq_enable(USART0_IRQn, 0, 0);
LED初始化:
GPIO_InitTypeDef GPIO_InitStruct = {0};
/*GPIO Port Clock Enable */
/*Configure GPIO pin : PtPin PA8*/
GPIO_InitStruct.gpio_periph = GPIOA;
GPIO_InitStruct.mode = GPIO_MODE_OUTPUT;
GPIO_InitStruct.pin = GPIO_PIN_8;
GPIO_InitStruct.otype = GPIO_OTYPE_PP;
GPIO_InitStruct.speed = GPIO_OSPEED_50MHZ;
GPIO_InitStruct.pull_up_down = GPIO_PUPD_NONE;
gpio_mode_set(GPIO_InitStruct.gpio_periph,GPIO_InitStruct.mode,GPIO_InitStruct.pull_up_down,GPIO_InitStruct.pin);
/*Configure GPIO pin Output Level */
gpio_output_options_set(GPIO_InitStruct.gpio_periph,GPIO_InitStruct.otype,GPIO_InitStruct.speed,GPIO_InitStruct.pin);
GPIO_BC(GPIO_InitStruct.gpio_periph) = GPIO_InitStruct.pin;
/* EXTI interrupt init*/
主程序代码:
int main(void)
e_at_state at_state = e_init;
/* enable DMA clock */
init();
led_flash(5);
while(1) {
switch (at_state)
case e_init:
sat('ATE0rn', 'OK');
if(!sat('ATrn', 'OK')){
led_on();
at_state = e_at_ok;
else{
delay_1ms(100);
led_off();
break;
case e_at_ok:
if(!sat('AT+CWJAP='testssid','12345678'rn', 'WIFI GOT IP'))
at_state = e_wifi_ok;
else{
delay_1ms(100);
break;
case e_wifi_ok:
if(!sat('AT+CIFSRrn', 'CIFSR:STAIP'))
at_state = e_sock_ok;
else
delay_1ms(100);
break;
case e_sock_ok:
//close socket
sat('AT+CIPCLOSErn', 'OK');
//start a new socket
if(!sat('AT+CIPSTART='TCP','192.168.1.36',1314rn', 'CONNECT'))
//sat('AT+CIPSEND=10','OK');
at_state = e_connect_ok;
else
delay_1ms(100);
break;
case e_connect_ok:
char at_resp[128] = {0};
wait_atrsp(at_resp);
if(strstr(at_resp,'on')){
printf('light onn');
led_on();
else if(strstr(at_resp,'off')){
printf('light offn');
led_off();
else if(strstr(at_resp, 'blink'))
printf('buling bulingn');
led_flash(10);
else
printf('other cmd got:[%s]rn', at_resp);
break;
default:
printf('Get into other:%dn',at_state);
break;
//delay_1ms(100);
待改善
usart接收数据采用关键字判断结束,效率较低;
at指令接收没有超时,如果得不到期望结果会卡住;
socket异常断开没有做处理;
后面可以接一个继电器控制插座或者台灯
因为esp01升级不到最新版本,无法支持mqtt,只能点对点控制玩玩了,支持mqtt就可以做更多事情;
异步中断处理usart_interrupt_flag_get不是很理解,正常接收或者发送完数据应该是可以退出,但是好像一直无法退出,不知道是使用的问题还是哪里出的问题,有经验的大神可以交流交流指导指导。
- 在GD32F310开发板上进行MultiTimer移植与分析
- 如何对GD32F310开发板的外部中断进行测试呢
- 基于GD32F310使用串口的空闲中断完成不定长数据的接收
- GD32F310开发板串口的数据接收与数字自动转换
- 基于GD32F310 MCU的BLDC电机设计
- 如何利用GD32F310读取HDC1080环境温湿度
- GD32F310开发板试用--基于RTT Nano的RTT软件包使用
- GD32F310定时器采样MP6050并在彩色LCD上显示波形
- STM32连接ESP8266向oneNET上传数据
- STM32、ESP8266与MQTT连接阿里云物联网的串口通信异常解析
- 六大全新产品系列推出,MCX A微控制器家族迎来创新
- 意法半导体全新STM32C5系列,重新定义入门级微控制器性能与价值,赋能万千智能设备
- 模组复用与整机重测在SRRC、CCC、CTA/NAL认证中的实践操作指南
- 有源晶振与无源晶振的六大区别详解
- 从控制到系统:TI利用边缘AI重塑嵌入式MCU的边界
- 英飞凌持续巩固全球微控制器市场领导地位
- 使用 Keil Studio for Visual Studio Code开发 STM32 设备
- 蓝牙信道探测技术原理与开发套件实践
- Microchip 推出生产就绪型全栈边缘 AI 解决方案,赋能MCU和MPU实现 智能实时决策
- LoRa、LoRaWAN、NB-IoT与4G DTU技术对比及工业无线方案选型分析
