单片机
ESP32-OTA升级
2025-09-10 来源:cnblogs
基于ESP-IDF4.1
  1 #include
  2 #include 'freertos/FreeRTOS.h'
  3 #include 'freertos/task.h'
  4 #include 'esp_system.h'
  5 #include 'esp_event.h'
  6 #include 'esp_log.h'
  7 #include 'esp_ota_ops.h'
  8 #include 'esp_http_client.h'
  9 #include 'esp_flash_partitions.h'
 10 #include 'esp_partition.h'
 11 #include 'nvs.h'
 12 #include 'nvs_flash.h'
 13 #include 'driver/gpio.h'
 14 #include 'protocol_examples_common.h'
 15 #include 'errno.h'
 17 #if CONFIG_EXAMPLE_CONNECT_WIFI
 18 #include 'esp_wifi.h'
 19 #endif
 21 #define BUFFSIZE 1024
 22 #define HASH_LEN 32 //sha256摘要长度
 23
 24 static const char *TAG = 'native_ota_example';
 25 //准备写入闪存的OTA数据写入缓冲区
 26 static char ota_write_data[BUFFSIZE + 1] = { 0 };
 27 extern const uint8_t server_cert_pem_start[] asm('_binary_ca_cert_pem_start');
 28 extern const uint8_t server_cert_pem_end[] asm('_binary_ca_cert_pem_end');
 29
 30 #define OTA_URL_SIZE 256
 31
 32 static void http_cleanup(esp_http_client_handle_t client)
 33 {
 34     esp_http_client_close(client);
 35     esp_http_client_cleanup(client);
 36 }
 37
 38 //__attribute__((noreturn)) 这个属性告诉编译器函数不会返回,这可以用来抑制关于未达到代码路径的错误。
 39 static void __attribute__((noreturn)) task_fatal_error(void)
 40 {
 41     ESP_LOGE(TAG, 'Exiting task due to fatal error...');
 42     (void)vTaskDelete(NULL);
 43
 44     while (1) {
 45         ;
 46     }
 47 }
 48
 49 static void print_sha256 (const uint8_t *image_hash, const char *label)
 50 {
 51     char hash_print[HASH_LEN * 2 + 1];
 52     hash_print[HASH_LEN * 2] = 0;
 53     for (int i = 0; i < HASH_LEN; ++i) {
 54         sprintf(&hash_print[i * 2], '%02x', image_hash[i]);
 55     }
 56     ESP_LOGI(TAG, '%s: %s', label, hash_print);
 57 }
 58
 59 static void infinite_loop(void)
 60 {
 61     int i = 0;
 62     ESP_LOGI(TAG, 'When a new firmware is available on the server, press the reset button to download it');
 63     while(1) {
 64         ESP_LOGI(TAG, 'Waiting for a new firmware ... %d', ++i);
 65         vTaskDelay(2000 / portTICK_PERIOD_MS);
 66     }
 67 }
 68
 69 //OTA升级任务
 70 static void ota_example_task(void *pvParameter)
 71 {
 72     esp_err_t err;
 73     //更新处理程序,通过esp_ota_begin()设置,必须通过esp_ota_end()释放
 74     esp_ota_handle_t update_handle = 0 ;
 75     const esp_partition_t *update_partition = NULL;
 76
 77     ESP_LOGI(TAG, 'Starting OTA example');
 78
 79     const esp_partition_t *configured = esp_ota_get_boot_partition();
 80     const esp_partition_t *running = esp_ota_get_running_partition();
 81
 82     if (configured != running) {
 83         ESP_LOGW(TAG, 'Configured OTA boot partition at offset 0x%08x, but running from offset 0x%08x',
 84                  configured->address, running->address);
 85         ESP_LOGW(TAG, '(This can happen if either the OTA boot data or preferred boot image become corrupted somehow.)');
 86     }
 87     ESP_LOGI(TAG, 'Running partition type %d subtype %d (offset 0x%08x)',
 88              running->type, running->subtype, running->address);
 89
 90     esp_http_client_config_t config = {
 91         .url = CONFIG_EXAMPLE_FIRMWARE_UPG_URL,
 92         .cert_pem = (char *)server_cert_pem_start,
 93         .timeout_ms = CONFIG_EXAMPLE_OTA_RECV_TIMEOUT,
 94     };
 95
 96 #ifdef CONFIG_EXAMPLE_FIRMWARE_UPGRADE_URL_FROM_STDIN
 97     char url_buf[OTA_URL_SIZE];
 98     if (strcmp(config.url, 'FROM_STDIN') == 0) {
 99         example_configure_stdin_stdout();
100         fgets(url_buf, OTA_URL_SIZE, stdin);
101         int len = strlen(url_buf);
102         url_buf[len - 1] = '';
103         config.url = url_buf;
104     } else {
105         ESP_LOGE(TAG, 'Configuration mismatch: wrong firmware upgrade image url');
106         abort();
107     }
108 #endif
109
110 #ifdef CONFIG_EXAMPLE_SKIP_COMMON_NAME_CHECK
111     config.skip_cert_common_name_check = true;
112 #endif
113
114     esp_http_client_handle_t client = esp_http_client_init(&config);
115     if (client == NULL) {
116         ESP_LOGE(TAG, 'Failed to initialise HTTP connection');
117         task_fatal_error();
118     }
119     err = esp_http_client_open(client, 0);
120     if (err != ESP_OK) {
121         ESP_LOGE(TAG, 'Failed to open HTTP connection: %s', esp_err_to_name(err));
122         esp_http_client_cleanup(client);
123         task_fatal_error();
124     }
125     esp_http_client_fetch_headers(client);
126
127     update_partition = esp_ota_get_next_update_partition(NULL);
128     ESP_LOGI(TAG, 'Writing to partition subtype %d at offset 0x%x',
129              update_partition->subtype, update_partition->address);
130     assert(update_partition != NULL);
131
132     int binary_file_length = 0;
133     //处理所有接收数据包
134     bool image_header_was_checked = false;
135     while (1) {
136         int data_read = esp_http_client_read(client, ota_write_data, BUFFSIZE);
137         if (data_read < 0) {
138             ESP_LOGE(TAG, 'Error: SSL data read error');
139             http_cleanup(client);
140             task_fatal_error();
141         } else if (data_read > 0) {
142             if (image_header_was_checked == false) {
143                 esp_app_desc_t new_app_info;
144                 if (data_read > sizeof(esp_image_header_t) + sizeof(esp_image_segment_header_t) + sizeof(esp_app_desc_t)) {
145                     //通过下载检查当前版本
146                     memcpy(&new_app_info, &ota_write_data[sizeof(esp_image_header_t) + sizeof(esp_image_segment_header_t)], sizeof(esp_app_desc_t));
147                     ESP_LOGI(TAG, 'New firmware version: %s', new_app_info.version);
148
149                     esp_app_desc_t running_app_info;
150                     if (esp_ota_get_partition_description(running, &running_app_info) == ESP_OK) {
151                         ESP_LOGI(TAG, 'Running firmware version: %s', running_app_info.version);
152                     }
153
154                     const esp_partition_t* last_invalid_app = esp_ota_get_last_invalid_partition();
155                     esp_app_desc_t invalid_app_info;
156                     if (esp_ota_get_partition_description(last_invalid_app, &invalid_app_info) == ESP_OK) {
157                         ESP_LOGI(TAG, 'Last invalid firmware version: %s', invalid_app_info.version);
158                     }
159
160                     //通过最新无效分区检查当前版本
161                     if (last_invalid_app != NULL) {
162                         if (memcmp(invalid_app_info.version, new_app_info.version, sizeof(new_app_info.version)) == 0) {
163                             ESP_LOGW(TAG, 'New version is the same as invalid version.');
164                             ESP_LOGW(TAG, 'Previously, there was an attempt to launch the firmware with %s version, but it failed.', invalid_app_info.version);
165                             ESP_LOGW(TAG, 'The firmware has been rolled back to the previous version.');
166                             http_cleanup(client);
167                             infinite_loop();
168                         }
169                     }
170 #ifndef CONFIG_EXAMPLE_SKIP_VERSION_CHECK
171                     if (memcmp(new_app_info.version, running_app_info.version, sizeof(new_app_info.version)) == 0) {
172                         ESP_LOGW(TAG, 'Current running version is the same as a new. We will not continue the update.');
173                         http_cleanup(client);
174                         infinite_loop();
175                     }
176 #endif
177
178                     image_header_was_checked = true;
179
180                     err = esp_ota_begin(update_partition, OTA_SIZE_UNKNOWN, &update_handle);
181                     if (err != ESP_OK) {
182                         ESP_LOGE(TAG, 'esp_ota_begin failed (%s)', esp_err_to_name(err));
183                         http_cleanup(client);
184                         task_fatal_error();
185                     }
186                     ESP_LOGI(TAG, 'esp_ota_begin succeeded');
187                 } else {
188                     ESP_LOGE(TAG, 'received package is not fit len');
189                     http_cleanup(client);
190                     task_fatal_error();
191                 }
192             }
193             err = esp_ota_write( update_handle, (const void *)ota_write_data, data_read);
194             if (err != ESP_OK) {
195                 http_cleanup(client);
196                 task_fatal_error();
197             }
198             binary_file_length += data_read;
199             ESP_LOGD(TAG, 'Written image length %d', binary_file_length);
200         } else if (data_read == 0) {
201            //由于esp_http_client_read从不返回负错误代码,因此我们依赖“errno”来检查底层传输连接关闭(如果有)
202             if (errno == ECONNRESET || errno == ENOTCONN) {
203                 ESP_LOGE(TAG, 'Connection closed, errno = %d', errno);
204                 break;
205             }
206             if (esp_http_client_is_complete_data_received(client) == true) {
207                 ESP_LOGI(TAG, 'Connection closed');
208                 break;
209             }
210         }
211     }
212     ESP_LOGI(TAG, 'Total Write binary data length: %d', binary_file_length);
213     if (esp_http_client_is_complete_data_received(client) != true) {
214         ESP_LOGE(TAG, 'Error in receiving complete file');
215         http_cleanup(client);
216         task_fatal_error();
217     }
218
219     err = esp_ota_end(update_handle);
220     if (err != ESP_OK) {
221         if (err == ESP_ERR_OTA_VALIDATE_FAILED) {
222             ESP_LOGE(TAG, 'Image validation failed, image is corrupted');
223         }
224         ESP_LOGE(TAG, 'esp_ota_end failed (%s)!', esp_err_to_name(err));
225         http_cleanup(client);
226         task_fatal_error();
227     }
228
229     err = esp_ota_set_boot_partition(update_partition);
230     if (err != ESP_OK) {
231         ESP_LOGE(TAG, 'esp_ota_set_boot_partition failed (%s)!', esp_err_to_name(err));
232         http_cleanup(client);
233         task_fatal_error();
234     }
235     ESP_LOGI(TAG, 'Prepare to restart system!');
236     esp_restart();
237     return ;
238 }
239
240 //诊断
241 static bool diagnostic(void)
242 {
243     gpio_config_t io_conf;
244     io_conf.intr_type    = GPIO_PIN_INTR_DISABLE;
245     io_conf.mode         = GPIO_MODE_INPUT;
246     io_conf.pin_bit_mask = (1ULL << CONFIG_EXAMPLE_GPIO_DIAGNOSTIC);
247     io_conf.pull_down_en = GPIO_PULLDOWN_DISABLE;
248     io_conf.pull_up_en   = GPIO_PULLUP_ENABLE;
249     gpio_config(&io_conf);
250
251     ESP_LOGI(TAG, 'Diagnostics (5 sec)...');
252     vTaskDelay(5000 / portTICK_PERIOD_MS);
253
254     bool diagnostic_is_ok = gpio_get_level(CONFIG_EXAMPLE_GPIO_DIAGNOSTIC);
255
256     gpio_reset_pin(CONFIG_EXAMPLE_GPIO_DIAGNOSTIC);
257     return diagnostic_is_ok;
258 }
259
260 void app_main(void)
261 {
262     uint8_t sha_256[HASH_LEN] = { 0 };
263     esp_partition_t partition;
264
265     //获取分区表的sha256摘要
266     partition.address   = ESP_PARTITION_TABLE_OFFSET;
267     partition.size      = ESP_PARTITION_TABLE_MAX_LEN;
268     partition.type      = ESP_PARTITION_TYPE_DATA;
269     esp_partition_get_sha256(&partition, sha_256);
270     print_sha256(sha_256, 'SHA-256 for the partition table: ');
271
272     //获取引导加载程序的sha256摘要
273     partition.address   = ESP_BOOTLOADER_OFFSET;
274     partition.size      = ESP_PARTITION_TABLE_OFFSET;
275     partition.type      = ESP_PARTITION_TYPE_APP;
276     esp_partition_get_sha256(&partition, sha_256);
277     print_sha256(sha_256, 'SHA-256 for bootloader: ');
278
279     //获取运行分区的sha256摘要
280     esp_partition_get_sha256(esp_ota_get_running_partition(), sha_256);
281     print_sha256(sha_256, 'SHA-256 for current firmware: ');
282
283     const esp_partition_t *running = esp_ota_get_running_partition();
284     esp_ota_img_states_t ota_state;
285     if (esp_ota_get_state_partition(running, &ota_state) == ESP_OK) {
286         if (ota_state == ESP_OTA_IMG_PENDING_VERIFY) {
287             // 运行诊断功能 ...
288             bool diagnostic_is_ok = diagnostic();
289             if (diagnostic_is_ok) {
290                 ESP_LOGI(TAG, 'Diagnostics completed successfully! Continuing execution ...');
291                 esp_ota_mark_app_valid_cancel_rollback();
292             } else {
293                 ESP_LOGE(TAG, 'Diagnostics failed! Start rollback to the previous version ...');
294                 esp_ota_mark_app_invalid_rollback_and_reboot();
295             }
296         }
297     }
298
299     // 初始化NVS
300     esp_err_t err = nvs_flash_init();
301     if (err == ESP_ERR_NVS_NO_FREE_PAGES || err == ESP_ERR_NVS_NEW_VERSION_FOUND) {
302         //OTA应用程序分区表有一个比非OTA分区表更小的NVS分区。大小不匹配可能导致NVS初始化失败,如果发生这种情况,我们擦除NVS分区并在此初始化NVS
303         ESP_ERROR_CHECK(nvs_flash_erase());
304         err = nvs_flash_init();
305     }
306     ESP_ERROR_CHECK( err );
307
308     ESP_ERROR_CHECK(esp_netif_init());
309     ESP_ERROR_CHECK(esp_event_loop_create_default());
310
311     //连接网络
312     ESP_ERROR_CHECK(example_connect());
313
314 #if CONFIG_EXAMPLE_CONNECT_WIFI
315     //确保禁用低功耗模式,这样可以提供最佳的吞吐量从而节省OTA操作的时间
316     esp_wifi_set_ps(WIFI_PS_NONE);
317 #endif
318     xTaskCreate(&ota_example_task, 'ota_example_task', 8192, NULL, 5, NULL);
319 }
进入单片机查看更多内容>>
相关视频
  • 【TI MSPM0 应用实战】智能小车+工业角度编码器+血氧仪+烟雾探测器!硬核参考设计详解!
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
  • 直播回放: Microchip Timberwolf™ 音频处理器在线研讨会
  • 基于灵动MM32W0系列MCU的指夹血氧仪控制及OTA升级应用方案分享
精选电路图
  • 1瓦线性调频增强器
  • 1瓦四级调频发射机
  • 500W MOS场效应管电源逆变器,12V转110V/220V
  • 红外开关
  • LM317过压保护
  • 0-30V/20A 大功率稳压电源(采用LM338)
    相关电子头条文章
