单片机
51单片机与MATLAB串口传图播放bad apple
2025-10-17 来源:bilibili
MATLAB部分
1.main1.m   视频转文档
var leng=0;
var re1=0;
var renum=0;
obj = VideoReader('D:51单片机编程辅助程序编写区chuanKouPicnewfangzhenbadap.mp4');%输入视频位置
numFrames = obj.NumberOfFrames;% 帧的总数
disp(numFrames);
re1=0;
 for i = 1:3:numFrames  % 读取前1帧
     frame = read(obj,i);%读取第几帧
    k= imresize(frame,[48,96]);
     thresh=graythresh(k);%确定二值化阈值
    B=im2bw(k,thresh);%对图像二值
    imshow(B);
    % imshow(frame);%显示帧
    disp(length(B));
    leng=length(B);
     fid=fopen('D:51单片机编程辅助程序编写区chuanKouPicnewfangzhenpic22.txt','a');
    for pag=1:1:6
     for ii=1:1:leng
        for iii=1:1:8
         re1=re1 + B(iii+8*(pag-1),ii)*(2^(iii-1));
        end
        iii=1;
        %disp(dec2bin(re1,8));
        fprintf(fid,'%s',dec2hex(re1,2));
         renum=fprintf(fid,'%s',',');
        %fwrite(s,'0101010101') ;%%s
        re1=0;
      % dec2bin(re1,8);%re yi
       disp(',')
     end
     ii=1;
    end
    for ei=1:1:96
        fprintf(fid,'%s','00');
    end
    fclose(fid);
 end
2.main2 文档解读与串口传数据
s=serial('COM3','Timeout',10,'DataBits',8,'BaudRate',9600);
%site(s,'Timeout',5,'DataBits',4);
get(s);
fclose(s);
file=fopen('D:51单片机编程辅助程序编写区chuanKouPicnewfangzhenpic22.txt','r');
%file1=str2num('5');
fopen(s);
i=0;
while 1%i<96*9*1600
  file1=  fscanf(file,'%c',1);
  file10=abs(file1);
if file10 ~=abs(',')
  if file10 >= 48&&file10<=58
      file10=abs(file1)-abs('0');
  end
  if file10 >= 65&&file10<=72
      file10=abs(file1)-abs('A')+10;
  end
%  file10= dec2bin(file10);
  disp(file10);
 %%fwrite(s,file10);
% fprintf(s,'%c',file1);
end
  file2=  fscanf(file,'%c',1);
  file11=abs(file2);
if file11 ~=abs(',')
  if file11 >= 48&&file11<=58
      file11=abs(file2)-abs('0');
  end
  if file11 >= 65&&file11<=72
      file11=abs(file2)-abs('A')+10;
  end
  disp(file11);
  file12=file10*16+file11;
 fwrite(s,file12);
end
i=i+2;
end
fclose(s);
fclose(file);
C51部分
user部分
main.c
 #include "usart.h"
  #include"spi.h"
  #include "LCD9648.h"
  #include "calculate.h"
  #include <stdio.h>
  #define WAY   1
  sbit led1=P1^1;
uchar rec;    // 2
int ii=0;      //+u
int flag=0;
#if WAY > 0
int jj=0;
#else if  WAY==0
int jj=0;
#endif
 void main()
    PCON &= 0x7F; //波特率不倍速
SCON = 0x50; //8位数据,可变波特率
// AUXR &= 0xBF; //定时器1时钟为Fosc/12,即12T
// AUXR &= 0xFE; //串口1选择定时器1为波特率发生器
TMOD &= 0x0F; //清除定时器1模式位
TMOD |= 0x20; //设定定时器1为8位自动重装方式
//   TH1=0XFd;   //u
// TL1=0XFd; //9600   //u
TL1 = 0xfd; //设定定时初值 fd
TH1 = 0xfd; //设定定时器重装值 //19200
// TL1 = 0xff; //设定定时初值
// TH1 = 0xff; //设定定时器重装值 //38400
ET1 = 0; //禁止定时器1中断
TR1 = 1; //启动定时器1
REN=1;
EA=1;
ES=1;
         LCD_Init();
Clear();
poseSign(0,0);
flag=0;
     while(1)
// ES=0;
          if(flag==1)
  if(jj<96+2)
          {jj++;WriteData((int)*&sendarray[0]);}//try} //+u
          if(jj==96+2)
               jj=1;
            ii=(ii+1)%7;
           poseSign(ii,jj-1);    //+u
// WriteData((int)*&sendarray[0]);   //one make a large influence
           jj++;
flag=0;
ES=1; //
//ES=1;
void IRQfun2() interrupt 4  //timer0
REN=0;
    #if WAY >0
    // static unsigned char j=-1; ////////+u
//unsigned char charistic; //+u
//+u
sendarray[0]=SBUF;
if(RI=1)
       if(flag==0)
   flag=1;
   ES=0;//
#else if  WAY==0
sendarray[0]=SBUF;
   if(RI=1)
if(jj==0)
        //    WriteData((int)*&sendarray[0]); //+u
// writenums(5,30,(int)jj);
  poseSign((int)*sendarray[0],0); //jj is count arg now
else
jj=(jj+1)%97;
SBUF=0;
#endif
REN=1;
RI=0;
calculate.c
 int count=0;
 float calcu()
   float g;
   g=0.75;
    g=(count*1000)/2;
   //return g;
   return g;
calculate.h
 #ifndef _CALCULATE_
 #define _CALCULATE_
  extern int count;
   float calcu();
 #endif
ChuanKou部分
usart.h
#ifndef _USART_H_
#define _USART_H_
#define uchar unsigned char
#include <REGX52.h>
  /*51 chuankou tongxin */
  #pragma SAVE
      #pragma REGPARMS
void initusart( int way,int timer,long time,int smode,int sm2); // chu shi chuan kou
#define usartWAY 1 ///chuan kou gong zuo fang shi
int sendByte(int way,uchar Byte, uchar tb8);
uchar receiveByte(int way, uchar rb8);
#define Mlength  20    /// chang du
extern uchar sendarray[Mlength];
extern uchar receivearray[Mlength];
//uchar otherArray[Mlength];
//1
int sendWord(uchar * psword);    // lun xun send
int receiveWord(uchar * prword);// lin xun receive
//2
 extern void sendWordauto(uchar * psword);    // lun xun send
 extern void receiveWordauto(uchar * prword);// lin xun receive
 void Uart_SendChar(unsigned char  dat);
      #pragma RESTORE
#endif
usart.c
 #include "usart.h"
 #include <stdio.h>
 uchar sendarray[Mlength];//="hello";
//1.way 工作方式 2.baud  3.定时时间   4.smode 0 1  5.SM2 0 1
    REN=0;TB8=0;RB8=0;TI=0;RI=0;
    PCON=smode; //bei zeng
    switch(way)
   case 2:
     SM0=1;//(way>>1)&0x01;
SM1=0;//way&0x01;
SM2=sm2;
     break;
   case 1:
  SM1=way&0x01;
  SM0=(way>>1)&0x01;
  SM2=sm2;
  TMOD=0x20;
  EA=1;
  ET1=1;
TH1=time<<timer;
TL1=time<<timer;
TF1=0;
TR1=1;
  break;
   if(way==2||way==3)
   {TB8=tb8;}
   else{TB8=1;}
   SBUF=Byte;
   while(!TI);
   return 2;
  uchar Byte;
Byte='a';
RI=0;
    if(SM2==0)
      {RB8=0;}
  if(SM2==1)
  {RB8==1;}
    while(!RI);
  Byte=SBUF;
  RI=0;
  if(way==2||way==3)
      {rb8=RB8;
  //if tb8==1 ......
  else{;}
  return Byte;
 int sendWord(uchar* psword)    // lun xun send
 { uchar * word;
    int i;
word=psword;
    for(i=0;i<Mlength;i++)
  sendByte(usartWAY,*word, 1);
    TI=0;
if(*word=='')
{break;}
word=word+1;
word=psword;
return 3;
int receiveWord(uchar* prword)  // lun xun receive   &receivearray[Mlength]
{  uchar * word;
   int i;
word= prword;
    REN=1;
  for( i=0;i<Mlength;i++)
    *word= receiveByte(usartWAY, 1);
      RI=0;
if(*word=='') //receivearray[word]==''
{break;}
word++;
    REN=0;
   return 4;
/////////////////////////////////zi dong length str/////
extern void sendWordauto(uchar* psword)    // lun xun send ES=0
   uchar * word;
    for(word=psword;*word!='';word++)
Uart_SendChar(*word);
  Uart_SendChar('');
extern void receiveWordauto(uchar* prword)// lin xun receive
  uchar * word;
REN=1;
word=prword;
     while((*word=receiveByte(usartWAY, 1))!='')
word++;
word=prword;
REN=0;
////////////////////////////////////////////////ku////////////
char putchar(char c)//重定向
Uart_SendChar(c);
return c;
    //SBUF = dat;
    //while(!TI);
    //TI = 0;
sendByte(usartWAY,dat, 1);
TI=0;
LCD9648部分
lcd9648.h
#ifndef _LCD9648_H_
#define _LCD9648_H_
#include <REGX52.h>
sbit CS0  = P0^0; //片选
sbit RST  = P0^1; //复位
sbit RS   = P2^7; //数据命令选择端
void Delay10us(unsigned int c) ;
void WriteComm(unsigned int i);
void WriteData(unsigned int i);
void LCD_Init(void);
void Clear();
void Cleararea(int p,int l,int p2,int l2);
void poseSign(int p,int l);
void writeStr(int p,int l,uchar *str);
void SetPoint(int l,int y); //x<96 y<48
void writenum(int num);
void writenums(int p,int l,int num);
#endif
lcd9648.c
#include "spi.h"
 #include "oledfont.h"
void Delay10us(unsigned int c)  //误差 0us
//    unsigned char b;
    for(;c>0;c--);
       // for(b=3;b>0;b--);
    CS0 = 0;
RS  = 0;
SendDataSPI(i);
CS0 = 1;
    CS0 = 0;
RS  = 1;
SendDataSPI(i);
CS0 = 1;
void LCD_Init(void)
unsigned int i;
//CS0=0;
RST=1;
for(i = 0; i < 1000; i++);
RST=0;
RST=1;
    WriteComm(0xe2);   //软件复位
WriteComm(0xc8);   //0xC8普通方向选择选择反向,0xC0为正常方向
WriteComm(0xa0);   //0xA0段方向选择正常方向(0xA1为反方向
WriteComm(0x2f);
WriteComm(0x26);
WriteComm(0x81);   //背景光对比度
WriteComm(0x10);
WriteComm(0xaf);   //开启显示
void Clear()
unsigned char i,j;
for(i=0; i < 6; i++)
WriteComm(0x40);
WriteComm(0xb0+i);
WriteComm(0x10);
WriteComm(0x00);
for(j = 0; j < 96; j++)
WriteData(0x00);
unsigned char i,j;
for(i=p; i < p2; i++)
WriteComm(0x40);
WriteComm(0xb0+i);
WriteComm(0x10);
WriteComm(0x00);
l=l%96;
l2=l2%96;
for(j = l; j < l2; j++)
WriteData(0x00);
    WriteComm(0x40);
p=p%6;
WriteComm(0xb0+p);
l=l%96;
WriteComm(0x10+l/16);
WriteComm(0x00+l%16);
// WriteData(0xFF);  //u
// WriteData(0x00); //+u
// Delay10ms(100);  //uu
// clear();
{   uchar * word;
      int i;
      word=str;
    WriteComm(0x40);
p=p%6;
WriteComm(0xb0+p);
l=l%96;
    while(*word!='')
   for(i=0;i<6;i++)
   WriteData(F6x8[(*word)-0x20][i]);
   word++;
  word=str;
void SetPoint(int l,int y)  //x<96 y<48
   int p;int px;
    char pxA;
//   int i;
p=y/8;
px=y%8;
p=5-p;
px=7-px;
pxA=0x01<<px;
    WriteComm(0x40);
WriteComm(0xb0+p);
  l=l%96;
   WriteData(pxA); ///////////////////
        Delay10us(10); //try
int i;
i=0;
   for(i=0;i<6;i++)
   WriteData(F6x8[num-0x20+0x30][i]);
{ int b,s,g;
        b=0;s=0;g=0;
    WriteComm(0x40);
p=p%6;
WriteComm(0xb0+p);
l=l%96;
WriteComm(0x00+l%16); //set
if(num<1000)
{g= num%10;
s=(num%100)/10;
b=num/100;}
else
  b=s=g=0;
  num=0;
writenum(b);
writenum(s);
writenum(g);
oledfont.h
   #ifndef __OLEDFONT_H
#define __OLEDFONT_H
//常用ASCII表
//偏移量32
//ASCII字符集
//偏移量32
//大小:12*6
/************************************6*8的点阵************************************/
const unsigned char code F6x8[][6] =
0x00, 0x00, 0x00, 0x00, 0x00, 0x00,// sp
0x00, 0x00, 0x00, 0x2f, 0x00, 0x00,// !
0x00, 0x00, 0x07, 0x00, 0x07, 0x00,// "
0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14,// #
0x00, 0x24, 0x2a, 0x7f, 0x2a, 0x12,// $
0x00, 0x62, 0x64, 0x08, 0x13, 0x23,// %
0x00, 0x36, 0x49, 0x55, 0x22, 0x50,// &
0x00, 0x00, 0x05, 0x03, 0x00, 0x00,// '
0x00, 0x00, 0x1c, 0x22, 0x41, 0x00,// (
0x00, 0x00, 0x41, 0x22, 0x1c, 0x00,// )
0x00, 0x14, 0x08, 0x3E, 0x08, 0x14,// *
0x00, 0x08, 0x08, 0x3E, 0x08, 0x08,// +
0x00, 0x00, 0x00, 0xA0, 0x60, 0x00,// ,
0x00, 0x08, 0x08, 0x08, 0x08, 0x08,// -
0x00, 0x00, 0x60, 0x60, 0x00, 0x00,// .
0x00, 0x20, 0x10, 0x08, 0x04, 0x02,// /
0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E,// 0
0x00, 0x00, 0x42, 0x7F, 0x40, 0x00,// 1
0x00, 0x42, 0x61, 0x51, 0x49, 0x46,// 2
0x00, 0x21, 0x41, 0x45, 0x4B, 0x31,// 3
0x00, 0x18, 0x14, 0x12, 0x7F, 0x10,// 4
0x00, 0x27, 0x45, 0x45, 0x45, 0x39,// 5
0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30,// 6
0x00, 0x01, 0x71, 0x09, 0x05, 0x03,// 7
0x00, 0x36, 0x49, 0x49, 0x49, 0x36,// 8
0x00, 0x06, 0x49, 0x49, 0x29, 0x1E,// 9
0x00, 0x00, 0x36, 0x36, 0x00, 0x00,// :
0x00, 0x00, 0x56, 0x36, 0x00, 0x00,// ;
0x00, 0x08, 0x14, 0x22, 0x41, 0x00,// <
0x00, 0x14, 0x14, 0x14, 0x14, 0x14,// =
0x00, 0x00, 0x41, 0x22, 0x14, 0x08,// >
0x00, 0x02, 0x01, 0x51, 0x09, 0x06,// ?
0x00, 0x32, 0x49, 0x59, 0x51, 0x3E,// @
0x00, 0x7C, 0x12, 0x11, 0x12, 0x7C,// A
0x00, 0x7F, 0x49, 0x49, 0x49, 0x36,// B
0x00, 0x3E, 0x41, 0x41, 0x41, 0x22,// C
0x00, 0x7F, 0x41, 0x41, 0x22, 0x1C,// D
0x00, 0x7F, 0x49, 0x49, 0x49, 0x41,// E
0x00, 0x7F, 0x09, 0x09, 0x09, 0x01,// F
0x00, 0x3E, 0x41, 0x49, 0x49, 0x7A,// G
0x00, 0x7F, 0x08, 0x08, 0x08, 0x7F,// H
0x00, 0x00, 0x41, 0x7F, 0x41, 0x00,// I
0x00, 0x20, 0x40, 0x41, 0x3F, 0x01,// J
0x00, 0x7F, 0x08, 0x14, 0x22, 0x41,// K
0x00, 0x7F, 0x40, 0x40, 0x40, 0x40,// L
0x00, 0x7F, 0x02, 0x0C, 0x02, 0x7F,// M
0x00, 0x7F, 0x04, 0x08, 0x10, 0x7F,// N
0x00, 0x3E, 0x41, 0x41, 0x41, 0x3E,// O
0x00, 0x7F, 0x09, 0x09, 0x09, 0x06,// P
0x00, 0x3E, 0x41, 0x51, 0x21, 0x5E,// Q
0x00, 0x7F, 0x09, 0x19, 0x29, 0x46,// R
0x00, 0x46, 0x49, 0x49, 0x49, 0x31,// S
0x00, 0x01, 0x01, 0x7F, 0x01, 0x01,// T
0x00, 0x3F, 0x40, 0x40, 0x40, 0x3F,// U
0x00, 0x1F, 0x20, 0x40, 0x20, 0x1F,// V
0x00, 0x3F, 0x40, 0x38, 0x40, 0x3F,// W
0x00, 0x63, 0x14, 0x08, 0x14, 0x63,// X
0x00, 0x07, 0x08, 0x70, 0x08, 0x07,// Y
0x00, 0x61, 0x51, 0x49, 0x45, 0x43,// Z
0x00, 0x00, 0x7F, 0x41, 0x41, 0x00,// [
0x00, 0x55, 0x2A, 0x55, 0x2A, 0x55,// 55
0x00, 0x00, 0x41, 0x41, 0x7F, 0x00,// ]
0x00, 0x04, 0x02, 0x01, 0x02, 0x04,// ^
0x00, 0x40, 0x40, 0x40, 0x40, 0x40,// _
0x00, 0x00, 0x01, 0x02, 0x04, 0x00,// '
0x00, 0x20, 0x54, 0x54, 0x54, 0x78,// a
0x00, 0x7F, 0x48, 0x44, 0x44, 0x38,// b
0x00, 0x38, 0x44, 0x44, 0x44, 0x20,// c
0x00, 0x38, 0x44, 0x44, 0x48, 0x7F,// d
0x00, 0x38, 0x54, 0x54, 0x54, 0x18,// e
0x00, 0x08, 0x7E, 0x09, 0x01, 0x02,// f
0x00, 0x18, 0xA4, 0xA4, 0xA4, 0x7C,// g
0x00, 0x7F, 0x08, 0x04, 0x04, 0x78,// h
0x00, 0x00, 0x44, 0x7D, 0x40, 0x00,// i
0x00, 0x40, 0x80, 0x84, 0x7D, 0x00,// j
0x00, 0x7F, 0x10, 0x28, 0x44, 0x00,// k
0x00, 0x00, 0x41, 0x7F, 0x40, 0x00,// l
0x00, 0x7C, 0x04, 0x18, 0x04, 0x78,// m
0x00, 0x7C, 0x08, 0x04, 0x04, 0x78,// n
0x00, 0x38, 0x44, 0x44, 0x44, 0x38,// o
0x00, 0xFC, 0x24, 0x24, 0x24, 0x18,// p
0x00, 0x18, 0x24, 0x24, 0x18, 0xFC,// q
0x00, 0x7C, 0x08, 0x04, 0x04, 0x08,// r
0x00, 0x48, 0x54, 0x54, 0x54, 0x20,// s
0x00, 0x04, 0x3F, 0x44, 0x40, 0x20,// t
0x00, 0x3C, 0x40, 0x40, 0x20, 0x7C,// u
0x00, 0x1C, 0x20, 0x40, 0x20, 0x1C,// v
0x00, 0x3C, 0x40, 0x30, 0x40, 0x3C,// w
0x00, 0x44, 0x28, 0x10, 0x28, 0x44,// x
0x00, 0x1C, 0xA0, 0xA0, 0xA0, 0x7C,// y
0x00, 0x44, 0x64, 0x54, 0x4C, 0x44,// z
0x14, 0x14, 0x14, 0x14, 0x14, 0x14,// horiz lines
#endif
SPI部分
spi.h
#ifndef _SPI_H_
#define  _SPI_H_
#include <REGX52.H>
sbit SCL  = P2^6; //SPI时钟端
sbit SDA  = P2^5; //SPI数据端
void Delay10ms(unsigned int c);   //误差 0us
void  SendDataSPI(uchar dat);
uchar SpiReceive();
#endif
spi.c
#include "spi.h"
void Delay10ms(unsigned int c)  //误差 0us
    unsigned char a,b;
    for(;c>0;c--)
        for(b=38;b>0;b--)
            for(a=130;a>0;a--);
   unsigned char i;
   for(i=0; i<8; i++)
      if( (dat&0x80)!=0 ) SDA = 1;
        else SDA = 0;
      dat <<= 1;
  SCL = 0;
      SCL = 1;
uchar SpiReceive()
  uchar byt0;
  int i;
  i=0;
  byt0=0x00;
   SCL=1;
  for(i=0;i<8;i++)
     while(SCL==1);
     SCL=0;//下降沿输入数据
   byt0<<=1;
   byt0|=(uchar)SDA;
   Delay10ms(1);
return(byt0);
进入单片机查看更多内容>>
相关视频
  • 【TI MSPM0 应用实战】智能小车+工业角度编码器+血氧仪+烟雾探测器!硬核参考设计详解!
  • 2022 Digi-Key KOL 系列: 你见过1GHz主频的单片机吗?Teensy 4.1开发板介绍
  • TI 新一代 C2000™ 微控制器:全方位助力伺服及马达驱动应用
  • MSP430电容触摸技术 - 防水Demo演示
  • 直播回放: Microchip Timberwolf™ 音频处理器在线研讨会
  • 基于灵动MM32W0系列MCU的指夹血氧仪控制及OTA升级应用方案分享
精选电路图
  • 1瓦线性调频增强器
  • 12V 转 28V DC-DC 变换器(基于 LM2585)
  • 红外遥控音量控制
  • LM317过压保护
  • 12V转110V/220V 500W逆变器
  • DS1669数字电位器
    相关电子头条文章
